Threads: 476
81
Car Model/Spec: 306 Rallye
Hi Guys,
After having the 1.8 on track I have only got a few mm left on my tyres. The brakes that are on it are random ones I threw on when my last pads were down to the metal.
I am now looking for 4 tyres which will be good on track and for fast road. 195/50/15. Old tyres were Yokohamas and goodyear eagle F1s which I thought were pretty good. What would people recommend? Looking at around £50 a corner.
Currently running 266mm brakes but id like to get some drilled and grooved discs on there with some green stuff pads. What brand of discs are decent?
I have some drilled and grooved discs for the back so Ill be putting those on. Is it worth putting green stuff pads on the rear?
266mm brakes are the biggest I can fit under the fondmetals. Im not on track often so I want to use the same set of tyres for road and track.
Cheers
Sam
Threads: 581
195
I had eagle F1s on the Winis when Scott gave them to me and they were good until they got to 2mm then turned to absolute shite.
If you can afford them, Pilot sport 3s. Imo, you can't beat them and I'm sure a lot of others will agree but you will pay a premium for them.
Threads: 476
81
(11-06-2014, 07:34 PM)Niall Wrote: I had eagle F1s on the Winis when Scott gave them to me and they were good until they got to 2mm then turned to absolute shite.
£56 a corner. Camskill
or £72.49 fitted on blackcircles.
Threads: 591
54
I would avoid drilled discs imho
Mintex 1144s seem the choice these day over cheap nasty green stuff pads.
and as regards tyres, depends if you intend on going on track more....
I think a compromise on track and on the road is pointless when you could get a set of 15" steels and part worn track tyres for probably under £150 if you were patient and careful. Then you can choose some tyres more suited to british roads
Threads: 465
114
Car Model/Spec: Vauxhall
wouldnt bother with the groved drill discs
std cheap discs with green stuff for the estate on the front and std pads on the back on std discs
stops the big bus well
green stuff pads will work from cold , but once they warm up they get a lot better. driving the motorway for a while then braking to a stop you will notice this more
red and yellow will need warming before they work well
Threads: 23
3
Car Model/Spec: High Boost Rallye
Given 1 thank(s) in 1 post(s)
Greenstuff are supposed to be shite.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
Threads: 106
7
Car Model/Spec: GTi-6
I use ferodo ds2500's, awesome pads.
Also, I run Yokohama a048r semi slicks on the road and track.... excellent tyre, but not sure what they'd be like on a daily...
JP
Threads: 465
114
the a048's on mine make the steering real heavy even with power steering
Threads: 476
81
Were the a048s with a soft compound? looks about £131 a tyre without VAT and fitting.
Think Ill have to go for the PS3s
Threads: 106
7
I run the medium compound on mine, the ones I gave cully were medium-hard.
JP
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
I use the yoko ad08r's, I've found them good so far. As for discs the brembo Max's have been good for me and using them with the 4pots and all.
Threads: 141
35
Running marangoni zeta liners on my 6,all time favourite Road tyres, although they're pretty soft compound so probably not the best for daily use. Can't remember off the top of my head how much they are each but seriously good tyres
As for pads, mintex 1144 and well serviced calipers have never let me down
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
12-06-2014, 02:21 PM
(This post was last modified: 12-06-2014, 02:22 PM by silverzx.)
Threads: 48
5
Car Model/Spec: Peugeot 306 S16 Cossack
Given 2 thank(s) in 2 post(s)
Ferodos are brilliant, better than 1144's. Just not sure if worth the extra wonga
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 266
18
1144's are "supposed" to be quite dusty when abused on track and won't last all that long.
Can't comment from personal experience unfortunately.
The mintex's I did run seemed all right for road use..
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
As said, avoid drilled/grooved altogether, a good OEM disc is the best way to go on a road car. In the unlikely event that you are cooking brakes there's more likely to be something wrong than a requirement for an upgraded disc.
Threads: 117
119
1144s on decent quality vented discs, decent dot 5.1 fluid and michelin ps3s. Stood up to ALL of the abuse for 5k, track time, nurburgring, mountain passes, the lot. No fade on long downhills, no surprising changes in performance, easy to drive and was getting good rates of wear too.
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
How long are peoples ps3s lasting? And has anyone ran them stretched? Would like to try them next but i keep hearing of their soft sidewalls but would still want to run 195/45 on an 8j
Threads: 581
195
(15-06-2014, 03:45 PM)Slam Wagon Wrote: How long are peoples ps3s lasting? And has anyone ran them stretched? Would like to try them next but i keep hearing of their soft sidewalls but would still want to run 195/45 on an 8j
Mine are lasting very well. Ive done 3k roughly on them now i think and they have barely worn. Still easily 6-7mm on them
Also, mine are ever so slightly stretched. Im running 195/45 on 7.5J with no issues at all.
Threads: 62
1
Car Model/Spec: Megane 265 + SHB Gti 6
Given 6 thank(s) in 6 post(s)
At fcs I was running 1144's with ad08r's no problem with the brakes at all...
next time I buy a set I am going for r888's though
Threads: 106
7
R888 < A048R.... In my opinion.
JP
Threads: 476
81
Need to order some PS3s. Annoying as I have 3 new Rainsport 2s but they will be terrible on track.
Threads: 106
7
If you've got 16's, buy my spare A048r's
JP
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
Given 40 thank(s) in 40 post(s)
Brembo max discs, havent warped mine yet and drive like c*nt. coupled with 1144's theyre really good stopping power, rear is pretty much unimportant as you barely brake with the rear anyway so genuine standard stuff should do.
as for tyres go for goodyear eagle f1's or yoko parada spec2's. perform equally well.
Team Cyril
Threads: 62
1
(16-06-2014, 07:50 AM)jammapic Wrote: R888 < A048R.... In my opinion.
If you look at anyone's car who is fairly quick around the track an find it when it's parked up 99% of the time it's r888
That 650 bhp evo thas had thousands spent on it runs r888 they must be doing somthing right
Threads: 55
17
Car Model/Spec: 406 V6
Yes, but mainly because R888's used to be so much cheaper than A048R's. Now that's not the case because they've got so popular, I see no real reason not to go with A048R's.
Threads: 62
1
Suppose will have to try both
Threads: 42
28
its fast road, not track car!
you need quite different suspension for AO48's, much harder spring rates, R888's not as much so as they're not a full on race tyre, having said that I know guys that have run the Yoko on the road
PS3 anyway.
Threads: 476
81
Think ill order some PS3s.
