Wanted: Lower plastic timing belt cover
Because peugeot is rediculous, they have included about a thousandth of a milimeter of between the bolt, and the actual plastic cover.
I am now in need of a lower timing belt cover plastic after an accident with a hammer broke mine,
anyone got a spare one kicking around?
a picture would be stunning to start with just to make sure the lower pulley is the same. (dunno, might be different), you never know
/Toseland
No one has this?
/Toseland
Same as the HDi one? If so I might have one, had 3 sets but have had a dumping session since lol.
if it is, great, not 100% sure tho, the genius at peugeot stuck, not only 1 thing in the way, but made it so it is near on impossible to get any form of spanner on the actual nut itself holding the lower section on.. hence now i need one..
/Toseland
XU so would have thought similar to the 6?
  XUD Timing cover and Engine mount. Alex 6 3,892 08-04-2014, 11:27 AM
Last Post: Alex
  Rad hose, bottom cam belt cover and oil sensor Niall 7 3,909 10-12-2013, 09:43 AM
Last Post: Chris
  timing belt kit / waterpump xud paul7278 1 1,880 19-11-2013, 08:38 AM
Last Post: Chris_90
