Rad hose, bottom cam belt cover and oil sensor
As above i need:
- Top rad hose from either a 1.8 or XSI 16v. Ideally want the XSI one with the metal part and both rubber bits.
- Lower cam belt cover that bolts to the block and surrounds the crank pulley.
- Oil level sensor with the fly lead that goes in the front of the block.
- GTi throttle body bolts to bolt the throttle body to the manifold.
All in good nick and brought to the Christmas meet or posted please Smile
I have several throttle bodies. You can have one Smile I'll see if I can find it asap
Just need the bolts mate so if you have all 4, let me know and ill send you some money if you can stick them in the post to me Smile
Bump. Still after all of these parts Smile
If the cam covers and top hose are same as a xud I have those
Team Doesn't own a 306
There not unfortunately but thanks for the offer.
Didn't think so but worth a go no worries mate
Got a oil sensor and maybe the cam cover.
Will look later when I get home.
[Image: sig.jpg]
Thumbs Up Wanted: GTi Bottom rad hose Jonny81191 2 2,334 13-02-2015, 07:50 PM
Last Post: Jonny81191
  Wanted: Lower plastic timing belt cover toseland 4 2,892 10-06-2014, 08:39 PM
Last Post: Jaymes306
  FMIC L Elbow and Bottom Hose mspdan 3 2,827 05-04-2014, 01:09 PM
Last Post: mspdan
