Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
Doing the head, so might be a good idea to do the belt too (it is a good idea i know)
have 2 choices..
kit from pug, or kit from local motorfactors
any issue with using a good quality OEM one? or should i roll some Darwins up and spend for a pug one?
also, are there any differences in tooth count between the XUD variants? mine is an XUD9SD (turbo, cat, no IC) from a citroen.. best to check before as pug thinks its a (if i remember correctly) 136 tooth
/Toseland
Threads: 226
24
Car Model/Spec: A3 TDi
Given 0 thank(s) in 0 post(s)
Depends on the motor factor one if its a Gates or Continential it will be fine, if its a linglongshongchong i would be sceptical.
Threads: 91
12
Car Model/Spec: 306 D Turbo
~I always use a motorfactors kit, usually a continental belt plus gates pulleys/tensioners
Belts are the same across the range, even fit the XUD7 I believe
Threads: 26
4
Given 6 thank(s) in 6 post(s)
Gates, Continental, Dayco are all the very best.
theres 2 different types of idler pulleys and waterpumps though.
Threads: 128
21
gave the local motorfactors the number of it.. they use GATES kits so comes with the gates belt and associated peices.
/Toseland
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Can't go wrong with gates tbh
