original ride hieght hdi estate v reg
I was wondering about the original/correct ride height for the car, v reg 2L hdi estate, cant remember the tyre size off hand but they are the same all round ( some more worn than the others could someone quote the correct ride height and measured from where please, for front and rear.....help greatly appreciated and I have looked on here but cant find the info.
just read all the rear beam axle rebuild thread, so they rot?? corrode??, mine seems ok corrosion wise......
a press is needed to remove and install the arm bearing tubes??
car seems to lean slightly to the drivers side on level ground.........no creaks or banging, will check for swing arm bearing play and /or gap in bearing seal. and axle rubber mounts.......
Is it possible to grease the bearings via a grease nipple??
  Estate rear ride hight riveracing 4 2,958 16-08-2015, 02:20 PM
Last Post: maxzy
  improving ride quality thebluepearl 15 9,864 18-11-2014, 12:38 PM
Last Post: welshpug
  Original ride height Nicks306 3 2,686 01-06-2014, 05:15 AM
Last Post: cully
