Estate rear ride hight
Ok, I've got a recon rear axle for my estate car. I asked for it to be built with the torsion bars set one spline higher coz I'm fed up with the back of car dragging on the deck! Now I've got it all stripped out and on reassemble I've found the rear shocks aren't long enough! I should have realised this would happen. Anyone else come across this? Or know where I can get some longer shocks? They're 320mm centre to centre I need 350mm.
Cheers Martin
that's normal, you always need to compress/raise the arm to get the damper bolts in.
just put a brick or some think under the wheel and let the car down a bit so the bolt holes line up.
oh and you cant get longer shocks only shorter ones.
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
Ok, thanks fellas
You will need to much force to put the damper back to their place if the car still lifted up, You can use some tricks to put them back like a jack under the rear end arm of both side or as the Craig306 said, that will easily for you.
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
  Hdi estate rear beam for free WILL1000 3 3,166 01-09-2015, 12:40 PM
Last Post: WILL1000
  improving ride quality thebluepearl 15 10,010 18-11-2014, 12:38 PM
Last Post: welshpug
  Estate Rear Beam On A Phase 1 Dturbo seanyleary 8 5,910 19-07-2014, 01:18 PM
Last Post: Toms306
