Wheel hubs
Upgrading all to gti6 parts looking for new steering knuckles (i think there called) which go behind wheel hubs and the front arm ball joints slide into them, so if anyone knows a site that sells them or would I have to go to a peugeot dealer?
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
Anyone know? :p
Bit confused which part you are on about
Or is it called a hub carrier? Bit confused as to what it's called aswell! It's the actual bit where you slide the balljoint in and tighten up the pinch bolt Smile
You'd need gti hubs mate, they're a compete cast unit
http://www.carparts4less.co.uk/cp4l/c/Pe...8a1&000602
Do you know where i could get a complete cast unit dude? as this isnt the complete unit is it
think the hubs are std across the range other than bearing diameter and bottom ball joint hole size
gti hubs are 82mm dia bearings and could be 16mm or 18mm balljoints
some other modles are 72mm with 16mm or 18mm balljoints
(01-06-2014, 08:56 AM)BenDturbo1 Wrote: http://www.carparts4less.co.uk/cp4l/c/Pe...8a1&000602
For complete units, go second hand and clean them up, then drop in some bearings and new hub faces like the one you linked. As Cully says, they're standard across the range other than the bottom balljoints.
  406 HUBS thethorne 45 24,307 30-11-2016, 09:13 AM
Last Post: Janne L
  XUD hubs on Hdi ct-hdi 2 2,604 09-03-2015, 07:15 AM
Last Post: Dum-Dum
  hubs cluskie 6 4,150 14-09-2014, 03:47 PM
Last Post: 306gtiparts
