Which brake discs
Simple ish question really what would you recommend? Not looking to spend silly money
Last pair I got from ecp were pagid ones which have lasted well but have now warped so I need to get rid
Is it worth going to grooved discs? These have never really faded even with hard use
I was going to suggest pagid, but maybe not if you've knackered a set
standard mintex are good value
*waits for someone to tell me they're the same disc under different brand names
Personally can't stand grooved/drilled and grooved discs.. make an awful lot of racket, vibration through the brake pedal and have a tendency of cracking (drilled and grooved)
ecp have 50% off on disc and pads at the mo
Wink
(30-05-2014, 04:31 PM)cully Wrote: ecp have 50% off on disc and pads at the mo
Wink
Comes in at 17.58 per disc and tbh this what I'm probably going to end up buying just wondered if there was something better for around the same
Im on pagid discs and pads at the moment, put up with my abuse seeing as I have to make up for it in the braking zones becauseracecar
blimmey 18 quid for a disc!!
I presume they are front discs??
would you have an address or website address for this firm please.......
brilliant forum as everHeart
I've had Drivetec, Vetech - all the cheap brands and frankly, they're all wank. Brembos I can also safely include in that - the cheap ebay Brembo ones are terrible also - just warp instantly.
Went to a set of Pagids and not had a problem since - this is on my 306 mind.
(31-05-2014, 09:29 AM)pug306driver Wrote: blimmey 18 quid for a disc!!
Euro car parts http://www.eurocarparts.com/
or
Carparts4less http://www.carparts4less.co.uk/
thanks cullyBlushHeart
  Brake Discs JTaylor2005 40 18,147 09-04-2016, 06:19 PM
Last Post: Toms306
  Skimming brake discs lolsteve 13 7,668 29-08-2014, 06:41 PM
Last Post: Tom
  BRAKE DISCS GETTING SUPER HOT p306hot 5 3,133 04-08-2014, 09:08 AM
Last Post: londondan86
