28-05-2014, 07:29 PM
I have a spare key fob from an R reg 306 was wondering if it can be programmed to run alongside my w reg 306 key fob?
Key fobs
29-05-2014, 05:46 PM
Erm.. not sure if an R reg would have a RF fob...
if they both look the same it shouldn't be an issue, if the R reg one has a led stuck out the front and the other doesn't.... no dice.
29-05-2014, 05:51 PM
Both fobs no l.e.d. In either could do with a back up key and blip.
No It can't. Ph2 ones work on infra red where as Ph3 is RF so they both work in completely different ways
29-05-2014, 05:55 PM
Explain why it didn't work on my old 306 the previous owner had told me it required batteries and recoding to car
29-05-2014, 06:09 PM
(29-05-2014, 05:55 PM)thebluepearl1 Wrote: Explain why it didn't work on my old 306 the previous owner had told me it required batteries and recoding to car The previous owner lied to you then :p Circa 1999 PH3 was released with RF keys. They are not interchangeable with the old IR ones. Have a look at both where the key blade goes into the casing. If one of them is a IR one, it will have a small clear LED looking sender. If neither of them have anything like that, they are both PH3
29-05-2014, 06:36 PM
Some bloody friend he was ha ha it was ok though as I never used the fob as it was pointless locking the car, you could unlock it with a 20 pence piece
29-05-2014, 07:46 PM
(28-05-2014, 07:29 PM)thebluepearl1 Wrote: I have a spare key fob from an R reg 306 was wondering if it can be programmed to run alongside my w reg 306 key fob? (29-05-2014, 05:51 PM)thebluepearl1 Wrote: Both fobs no l.e.d. In either could do with a back up key and blip. (29-05-2014, 05:51 PM)Niall Wrote: No It can't. Ph2 ones work on infra red where as Ph3 is RF so they both work in completely different ways Yes it can as by the sounds of it, its a phase 3 key and his car is phase 3. So it will need programming with pp2000. Sorry just think you missed read some of it niall
29-05-2014, 07:49 PM
If there is no LED on the fob from the R reg then its not from an R reg and never worked with that car.
Didn't misread it. It can't be a PH2 fob if there is no LED
29-05-2014, 08:21 PM
Calm down chaps, simple mistake to make, so how do I go about getting it programmed? Is it as simple as turn key push and hold fob or pay a man with a laptop?
29-05-2014, 08:26 PM
(29-05-2014, 07:49 PM)Niall Wrote: If there is no LED on the fob from the R reg then its not from an R reg and never worked with that car. I know, but in the orignal post he was asking if it will work with his phase 3 and the key sounds like its phase 3. Sorry niall I re-read the post and its sounded a bit arsey didnt mean it to be. I was just pointing out that he was asking if it would work with his phase 3. He was just saying that it came with a phase 2 which is what made him think it was phase 2.
29-05-2014, 08:40 PM
(29-05-2014, 08:21 PM)thebluepearl1 Wrote: Calm down chaps, simple mistake to make, so how do I go about getting it programmed? Is it as simple as turn key push and hold fob or pay a man with a laptop? Right if your car is a PH3 then programming keys is done with PP2000 however, you can only program a key that was previously registered to that car or a brand new key. You can't take a key from a old car thats been scrapped for example and program that to your car. They are sort of one shot if you like.
29-05-2014, 09:42 PM
(29-05-2014, 08:40 PM)Niall Wrote:(29-05-2014, 08:21 PM)thebluepearl1 Wrote: Calm down chaps, simple mistake to make, so how do I go about getting it programmed? Is it as simple as turn key push and hold fob or pay a man with a laptop? Ok mate thanks for clearing that up for me. :-)
30-05-2014, 07:00 AM
Does anyone have the part number for a phase 3 rf key?
30-05-2014, 07:24 AM
I'll be requiring a new key fob then as I believe from your description I have a spare phase 3 fob so they won't be able to programme that as it's from a different car, thanks for the info
| rf key fobs | pug306driver | 5 | 2,841 |
21-01-2015, 09:56 AM Last Post: pug306driver |
| Programming Key Fobs with 1 or 2 buttons? | Smiley69 | 14 | 10,991 |
23-10-2012, 07:33 AM Last Post: Smiley69 |
