tools needed to remove a rear beam?
Hi all,
ive managed to find a good rear beam local to me on a car for breaking and have to remove it myself,
I know it bolts through the floor, does anyone know what tools ill need to make it easier/quicker for me?
cheers
steve
socket set. (deep sockets) & extension bars
pair of grips. depending on how you plan to release you hand brake cable
brake pipe spanners
Jacks and axel stands
and at least 1 friend makes things much easier
It is just a case of releasing hand brake / disconecting brake lines. Then undoing the 6 beam bolts in the floor
pipes and cables can be cut to make it easier Smile
thanks mate much appriciated
Just a deep 16mm and something to cut pipes for a scrapper beam tbh! Beams are easy to remove and not all that heavy after you've done a few, just an awkward shape really.
sweet, cheers all Smile
You will need to drop the exhaust down too. Or remove the backbox.
The end of the middle section of the exhaust gets a little in the way to.
Deep 13 for if you need to take exhaust off
Deep 16 for bolts in boot
Bolt crops for brake lines and cables 19mm for wheel bolts job done
Team Doesn't own a 306
  Rear beam ...the good and the bad Mighty306 35 31,570 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,429 26-06-2020, 07:19 AM
  rear ARB bush size needed. weka 5 6,494 05-04-2020, 01:55 PM
