21-05-2014, 06:02 PM
hi peps i see people are saying to pull out the anti roll bar then the torsion bars but is that needed or can you just pull out the torsion bars???
lowering the torsion bar
21-05-2014, 06:26 PM
You.wonet get the bars out without removing anti roll bat first. Take a look in guides section abour lowering
21-05-2014, 06:34 PM
Yes you need to remove the ARB first. What's the issue though, that's the easy bit?
21-05-2014, 06:47 PM
Just trying to save time lol do you know what size bolt I need to pull the arb out
21-05-2014, 07:07 PM
M12x1.5. You're best off reading the guide, it has everything you need in it.
21-05-2014, 07:57 PM
Thanks mate and where is the guide I'm new to the site
21-05-2014, 08:25 PM
xud headbolt is the right size - or rear caliper bolt that holds the carrier to the hub is also the right size (and possibly handy if you're doing a disc beam too)
21-05-2014, 09:21 PM
Cheers it on my hdi estate which is rear discs
25-05-2014, 03:24 PM
before and after
[attachment=16442][attachment=16443][attachment=16444][attachment=16445][attachment=16446]
25-05-2014, 06:33 PM
That's pretty low!
25-05-2014, 06:41 PM
Did you remember to put your bars back in?
25-05-2014, 07:01 PM
Yeah, that's a bit too low tbh, looks like it's broken and dragging it's arse around like a dog with worms!
26-05-2014, 07:46 AM
Nothing broke and it does sit about level, can't see the point in only half lowering a car lol
26-05-2014, 10:35 AM
I think the point is to lower them not that much so that there not sitting on the bump stops and ride horrible
26-05-2014, 12:28 PM
Still clearance from bump stops and is a softer ride then my 16v and seems to corner ok so I'm happy
28-05-2014, 03:25 PM
(26-05-2014, 07:46 AM)fubs Wrote: Nothing broke and it does sit about level, can't see the point in only half lowering a car lol You've only lowered the rear half though.
93 106 xsi
98 306 1.9d 98 306 1.9td lx 01 306 2.0hdi 97 306 1.9td estate 96 306 dturbo 96 306 dturbo
28-05-2014, 04:22 PM
looked low enough before!
level sucks, rake FTW
28-05-2014, 10:13 PM
Front is dropped but now it settled think I'll pull it down a bit more
28-05-2014, 10:19 PM
if you're happy that's what matters, personally i think it looks broke too and for me the front should always be lower than the back
30-05-2014, 10:12 AM
the cops are gunna think you have a safe in the back.......a "puller" if there ever was one.....I was worried about mine being low ( it has a tow bar on the back so has had a hardf life ) but seeing you pics I not any more.......
12-06-2014, 10:35 AM
I got front set of 60mm lowering springs for my 306 , do I have to get new shocks aswell or will the standard once do?
12-06-2014, 10:50 AM
Agreed 60mm is a bit much on standard shocks. But saying that im running standard shocks and 60 atm untill I can afford shocks
Thanks for the good times guys n gals. I might be back. Who knows. |
Lowering a torsion bar, nick method... | GP123 | 28 | 16,771 |
22-09-2021, 11:06 AM Last Post: Alan_M |
torsion bar lowering south east? | connorp | 1 | 1,173 |
26-02-2016, 10:43 AM Last Post: toseland |
Torsion bar lowering | Porty | 4 | 1,644 |
14-01-2016, 08:05 PM Last Post: Porty |
