lowering the torsion bar
hi peps i see people are saying to pull out the anti roll bar then the torsion bars but is that needed or can you just pull out the torsion bars???
You.wonet get the bars out without removing anti roll bat first. Take a look in guides section abour lowering Smile
Yes you need to remove the ARB first. What's the issue though, that's the easy bit?
Just trying to save time lol do you know what size bolt I need to pull the arb out
M12x1.5. You're best off reading the guide, it has everything you need in it.
Thanks mate and where is the guide I'm new to the site
xud headbolt is the right size - or rear caliper bolt that holds the carrier to the hub is also the right size (and possibly handy if you're doing a disc beam too)
Cheers it on my hdi estate which is rear discs
before and after
[attachment=16442][attachment=16443][attachment=16444][attachment=16445][attachment=16446]
That's pretty low!
Did you remember to put your bars back in?
What broke?
Yeah, that's a bit too low tbh, looks like it's broken and dragging it's arse around like a dog with worms! lol
Nothing broke and it does sit about level, can't see the point in only half lowering a car lol
I think the point is to lower them not that much so that there not sitting on the bump stops and ride horrible
Still clearance from bump stops and is a softer ride then my 16v and seems to corner ok so I'm happy
(26-05-2014, 07:46 AM)fubs Wrote: Nothing broke and it does sit about level, can't see the point in only half lowering a car lol
You've only lowered the rear half though. Undecided
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
looked low enough before!
level sucks, rake FTW
Front is dropped but now it settled think I'll pull it down a bit more
if you're happy that's what matters, personally i think it looks broke too and for me the front should always be lower than the back Smile
the cops are gunna think you have a safe in the back.......a "puller" if there ever was one.....I was worried about mine being low ( it has a tow bar on the back so has had a hardf life ) but seeing you pics I not any more.......
I got front set of 60mm lowering springs for my 306 , do I have to get new shocks aswell or will the standard once do?
60mm is a bit much a standard shocks.
Agreed 60mm is a bit much on standard shocks. But saying that im running standard shocks and 60 atm untill I can afford shocks
  Lowering a torsion bar, nick method... GP123 28 30,119 22-09-2021, 11:06 AM
Last Post: Alan_M
  torsion bar lowering south east? connorp 1 2,487 26-02-2016, 10:43 AM
Last Post: toseland
  Torsion bar lowering Porty 4 3,812 14-01-2016, 08:05 PM
Last Post: Porty
