Need move my Ecu so i can assess the fuses behind it, is it safe to remove it by following the battery removal procedure then unplugging the ecu?
307 ecu removal
11-05-2014, 03:50 PM
Yes. Shouldn't be a problem. So long as battery is disconnected
11-05-2014, 04:29 PM
Worked fine, fuses are fine so problem is somewhere else
11-05-2014, 04:33 PM
What's not working
11-05-2014, 09:39 PM
Radiators low fan, its supposed to come on when the A/C is turned on, I can get the high fan to work from PP2000 but not the low
12-05-2014, 12:05 AM
(This post was last modified: 12-05-2014, 12:05 AM by bashbarnard.)
Ac pump defiantly kick in?
Also it won't come on if its chilly enough
12-05-2014, 10:56 AM
check the relays.
