08-05-2014, 12:10 PM
Theres some black oversray from a rattle can on my rear lights, What would remove this without damageing, burning or fading the lights itself ?
Removing paint overspray
08-05-2014, 12:13 PM
Thinners on a rag?
08-05-2014, 12:36 PM
Would that not dis-colour and burn into the lense ?
08-05-2014, 12:42 PM
White spirit, wouldnt go anywhere near my car with thinners but white spirit is ok. dont confuse the two.
08-05-2014, 02:48 PM
Are you sure it wont fade the lense or damage it ?
08-05-2014, 03:27 PM
I wouldn't use any chemicals on plastic tbf, t cut will get It off no bother just put some elbow grease into it
08-05-2014, 03:56 PM
Autosol is the stuff.
08-05-2014, 04:05 PM
thinners is likely to melt the plastic!
08-05-2014, 05:24 PM
T-Cut is perfect for overspray.
Chris
08-05-2014, 05:30 PM
Just a polishing compound will do the trick mate, wouldn't advise using paint thinners unless you are experience in using that sort of thing
08-05-2014, 10:15 PM
Or use clay as it was originally designed to be for....
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
09-05-2014, 12:58 AM
Got them cleaned. I used watered down thinners and then g3'd them. Came up like new. Cheers fellas
09-05-2014, 06:26 AM
(08-05-2014, 10:15 PM)Jenkosowls Wrote: Or use clay as it was originally designed to be for.... This! Clay is intended to remove overspray, go on youtube and search for removing overspray - you'll find they recommend clay and show you how.
HDi Owner for 200k/9 years
10-05-2014, 10:39 AM
Clay bar is the best..
22-05-2014, 04:25 PM
+1 on the clay bar and detailing spray, as a little cheap skin flint trick you can use a spray bottle with some weak wash and wax solution and use some blue tac........yes blue tac!
not as effective as the real macoy but still gets it off quite well But if youve cleaned them up alread then this post is a little pointless i suppose but might be of help to somebody. |
| Tar spots...black overspray! (&claybar) | Piggy | 18 | 9,627 |
07-02-2016, 03:41 PM Last Post: ginge191 |
| shot blasting for wheels? removing paint | zx_volcane | 19 | 10,153 |
25-11-2015, 11:23 PM Last Post: daniel909 |
| Paint on paint removal | MRiches | 6 | 4,695 |
28-06-2013, 06:54 PM Last Post: Choppin |
