11mm lda grind. Had a drive
Drove pugmanxud s 205 with bosch on and his turbo only running 10 psi and to say the least I'm impressed and need one for my motor!
10 PSI on what turbo? That should be illegal!
I think it was a k14. The turbo was on its last legs his bolting up td04 soon. So much want for bosch now though. So next month I will be buying Smile
Hang on 11 mm at 10 psi on a k14
Why?
Team Doesn't own a 306
I think he said he was running a lot more then the turbo started to pack in hence the upgrade.
Yep. Can't work it out. Keep winding in the end screw with no difference. As soon as I have made the plates up and tigged the wastegate up it will be on!!
Lol an 11mm and a dewastegated td04 is a recipe for shitting your engine.
Really? Why
How to you reccomend controlling the boost?
Gearbox mount leave the actuator on. Or try and fit actuator down back of engine
I am told there is a bit more room on a 205 than a 306. May look at either option. What is a manual boost controller
  LDA grind? Nathan1305 13 6,925 25-01-2015, 09:39 PM
Last Post: Nathan1305
