29-04-2014, 05:15 PM
I took my coolant sensor out today to clean it and now that works fine but im loosing water from the expansion tank some how its just a drip but a constant drip is this a common problem
expansion tank seams to be leaking
29-04-2014, 06:34 PM
It looks like ive runed the rubber seal so its leaking from the sensor does anyone know if I can get a new o ring or will I need a new sensor
30-04-2014, 07:30 AM
How did you remove the sensor out of interest? I read on here that I need to just pull it but mine felt like it was going to break!
If you have the old o ring a motor factors should be able to replace it. Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
30-04-2014, 08:18 AM
You have to twist it 90 degrees then pull on it hard and got a o ring sorted now mate
Expansion tank!!! Help help! | conorpierce | 68 | 10,980 |
10-09-2015, 06:21 PM Last Post: DeeTurbo |
Expansion tank overflow/rad cap | pug306driver | 1 | 928 |
15-05-2015, 09:52 PM Last Post: Poodle |
