Removing brake compensator
As title has anyone done this? I wouldn't foresee it being an issue but you never know. Surely would only result in more braking force to the rear. Converting to discs on rear soon and want to drop it off basically.
yes i did it on my old 1.6, it's ok 99% of the time but slam on full and you can lose the back end . . up to you ..Smile
Ah I see. Might get a reducer in the brake line as well. I'm sure they exist
just get a cheap bias valve if your a bit unsure, ive been running my 1.6 without the comp for 2 years i think and only had the rear lock in extreme wet weather.
im running 266mm fronts brembo discs mintex pads and standard rear discs same again brembo and mintex
That's basically what I'm going to be running. Just with braided hoses too. I'll have a look at bias valve
  Rear brake compensator leaking Ben 4 5,967 24-04-2018, 07:11 PM
Last Post: Ben
  Brake compensator differences Ben_w 8 7,298 03-03-2018, 01:44 PM
Last Post: Mighty306
  Brake compensator rocker8742 1 2,755 22-05-2016, 12:28 PM
Last Post: cully
