306 HDI Water block / rad hose question (urgent :) )
Howdy,
Quick question for the HDI gurus, on the 306, does the lower rad hose still go on drivers side wing area and in around the back to the water pump distro block? Or does it come up across the front of the motor?
Does anyone have a photo of a 306 hdi engine from behind with the water block fitted?
Cheers, just got some compatibility issues as normal, and trying to find out if a 306 part will fix it, or if im going to have to just mod the crap out an xud one to make it fit!
xx
There pretty much the same as the xud, the lower rad pipe come out and along the chassis leg.
[Image: sig.jpg]
Ok, brings me onto next question, does anyone have one of these they can sell me? Smile
My mate should on his old hdi block, will ask later.
[Image: sig.jpg]
Thanking you Smile
As Chris said, it runs below the chassis leg and round the back of the block. not too expensive new from pug IIRC
Id rather give my money to someone on here than the robbing ****turds at my local pug dealer.
EDIT
I think I may have sorted this now, will let you know in a few days, thanks for your help! Smile
Not sure if its relevant for what you're doing but I'm pretty sure the hose clip on the hdi is like a c clip and on the DT is a jubillee...so HDi hose may not fit.
  water pressure (a very quick question) Magenta Sunset 34 17,551 12-04-2017, 11:24 AM
Last Post: welshpug
