406 elbow diameter
406 elbow diameter
Does anyone know off the top of there head the diameter of the c5 bottom turbo pipe and the 406 inlet elbow
51mm if I remember correctly
Bye Bye D-Turbo
What 406 inlet elbow are you using, one with the air dozer or without? I am not sure if they are the same or not.
And the c5 bottom pipe which end do you want to know, both ?
Is the air doser the erg???
(16-04-2014, 02:36 PM)tuttyboy84 Wrote: Is the air doser the erg???
It is part of the egr, and it is on the end of the inlet elbows on the later vehicles.
Ill try and get one without it and Im asking about the intercooler end of the c5 bottom pipe
I think 63 and 57
Thats a bit poo as the outlets on my intercooler are 51mm
(16-04-2014, 05:25 PM)tuttyboy84 Wrote: Thats a bit poo as the outlets on my intercooler are 51mm
You can get a reducer
Thats pretty standard. 51 is 2" and then 57 is 2.5". 51mm will be easier to fit past the rad and then somewhere in the piping you can step it up to 57 ready for the inlet.
I think ill use 2 inch pipe all the way to the inlet then use a reducer to fit it not sure how I can do the bottom pipe yet
90 degree reducer.
  Diameter of the elbow for turbo connection mattbarker32 5 2,805 18-09-2016, 08:14 PM
Last Post: toseland
  Lower air box pipe diameter? JTaylor2005 2 2,014 26-01-2016, 09:22 PM
Last Post: DeeTurbo
  Air filter inlet diameter aaron_one 5 2,811 02-11-2015, 02:06 PM
Last Post: aaron_one
