Wanted: help lowering rear beam
Just changed my wheels over and have noticed that my car is a bit tall, even though it has been lower 40mm all round. it looks as if it will need another 20mm to make it sit right.
Is there anyone that can help in hampshire area would be very grateful cheer
[attachment=15429]
Got to love it when you have no ideaDodgy
that's far more than 40mm already.
Yeah it may be but need to at least level back up
Is it just me or does the rear look lower than the front?!
^^ this, needs to come up a tad if anything. Or front down a little more
The back is about 10 mm higher than front It is the grass area that makes it look that way
that's spot on then front to rear ratio wise, however I would raise it an inch Tongue
This^^ (apart from the raising it thing...).
  Wanted: Rear Beam (Disc or drum) Eeyore 10 6,665 05-04-2016, 08:00 AM
  Wanted: solid rear beam mounts af1 0 1,673 31-05-2015, 06:34 PM
Last Post: af1
  Drum rear beam Matt 0 1,680 26-05-2015, 10:08 AM
Last Post: Matt
