pics of rear of instrument cluster
anyone have any pics of the rear of the 306 instrument cluster (speedo ..etc)
do the wiring connectors differ between phases?
which ones use a mech speedo cable?
Might want to try and wrangle one into the zx if its easy
Ta, thanks
Phase 1 is different to phase 2/3
I think phase 1s are mechanical speedo but don't hold me to that haha
Phase 1's upto around late 1995 ish are full mechanical speedo (ie cable driven)
Late Phase 1's (late 1995-1996 ish) are semi-electric speedo (ie electrically driven but with mechanical odometer)
Phase 2 and 3 (1996 onwards) are full electric speedo (ie electrically driven and with a digitial odometer)
I know that the wiring is very different between Phase 1 and Phase 2/3 but not sure on precise details - Phase 1 is similar style wiring/connectors to a ZX (but almost certainly not pin compatible) with slot style plugs around the outside of the back of the clocks, whereas Phase 2/3 use a couple of high density plugs from what I recall.
great info, thanks Smile
sounds like I'd need a bit of loom, a wiring diagram and some patience if I want to go down this route
(15-04-2014, 09:12 AM)powerandtorque Wrote: Phase 1's upto around late 1995 ish are full mechanical speedo (ie cable driven)
Yours is the same as an early Phase 1 with cable driven speedo, they won't be that vastly different I'd doubt...
Wanting to convert to electric speedo?
I have a pic of ph3 clocks....they're gonna be completely different to the ZX ones though.
(15-04-2014, 03:20 PM)Ruan Wrote: Yours is the same as an early Phase 1 with cable driven speedo, they won't be that vastly different I'd doubt...
Yeah this, should be able to route it easier and not melt the cable :/
  1998 306 Instrument cluster failure ashley744 5 4,769 06-05-2020, 08:11 AM
Last Post: Mighty306
  Instrument panel not not light up davie_b1972 3 4,248 18-03-2015, 04:29 PM
Last Post: Mattcheese31
  Replacing instrument panel, Help! Tamas Petrunin 3 3,925 19-02-2015, 10:18 PM
Last Post: Tamas Petrunin
