URGENT: passenger window won't go up
Passenger window won't go up. Drivers side works fine but on the drivers switch the passenger side won't go up or down but on the passenger switch the window only goes down!
Any ideas?
are both doors closed?
AND both switches connected?
Yes both doors closed and they were working fine today, can't pull the window up either :/
Sounds like door looms tbh
Team Doesn't own a 306
Possibly, give the looms a bit of a squeeze and try again, or leave it 5 minutes and come back to it!
The passenger window wire runs through the drivers loom as it goes to the drivers side switch first, so that's likely tbh. Could also be a faulty motor though.
You wont pull the window up against the motor tbh.
Sorted for now cheers lads. Toms comment gave me an idea Tongue I popped out the drivers switch and it started working off both switches but it would stop working so I had to keep the giving the switch a wiggle, got the window up, popped the switch back in and it still works so where do you guys think the problem is coming from?
So glad I didn't have to start taking sh*t apart at this time of night!
Viagra might help if your struggling to get it up mate!
  Passenger Window wont go up! mspdan 2 2,597 17-01-2015, 11:33 PM
Last Post: shazilla
  Wiring loom needed/passenger window stuck open... Mattinthehat 4 3,907 18-09-2014, 03:30 PM
Last Post: Mattinthehat
  passenger window doesnt run all the way back up wacker315 3 2,967 18-07-2014, 08:15 AM
Last Post: Richieboi13
