standard alloy wheel bolt lengths...
Would be interested to know the folllowing:
How long from washer to tip is the standard 306 alloy flat seated wheel bolt? (Shank length) I am led to believe it is 45mm?
How many MM protrude after going through a standard 306 alloy, IE a clone?
Thanks Smile
get tape measure out? . . .:p
35mm.
as for how much pokes out, no idea.
enough :p
Guessing 10mm sticking out?
Ive found standard second hand sets that are 45mm?
I would measure...but I have neither standard bolts or alloys to go measure!!
(10-04-2014, 05:41 PM)welshpug Wrote: 35mm.
enough :p
You sure its 35mm?
actually I was slightly out by 3mm, I thought they were the same as the 205 but they're marginally longer.
9605 87
16
ALUMINUM WHEEL SCREW
12X125-38
FOR WHEEL 5,5 J14
16
12X125-38
- INJECTION XU10J4RS
FOR WHEEL 6 J15
16
12X125-38
- ROLAND GARROS
FOR WHEEL 6 J15
So the 45mm ones I have found must be from something else.
Hmm.
quite likely, stick a picture up.
Thinking of running spacers then? I had his same issue when I was considering a set of 10mm spacers for the back of mine, couldn't find the information anywhere and too much of a lazy shit to go and measure one lol
[Image: Sig500x130.png]
  Alloy wheel stamp. Pugwash 5 5,226 05-06-2018, 03:15 PM
Last Post: Pugwash
  Alloy Wheel Bolts rdstars 2 2,729 16-03-2017, 05:01 PM
Last Post: rdstars
  turns of a wheel bolt? impotentials 10 5,177 20-10-2015, 07:21 AM
Last Post: Jonny81191
