09-04-2014, 09:10 AM
Is there a set amount of turns to shorten the wastegate for 22 psi or are they all trial and error
adjusting the wastegate
09-04-2014, 11:00 PM
Seem to remember this being trial and error... mine went quite a bit on this but not as much on my old hdi strangley
10-04-2014, 12:14 PM
10-04-2014, 12:36 PM
If fitting a boost controller then you still have tonadjut thw wastegate, but you over adjust it and then use the controller to bring it back down.
10-04-2014, 03:55 PM
Id rather just set the wastegate then not worry about it again and im pretty sure if fitting a boost controller you only interrupt the the pipe from turbine to wastegate rather than moving the wastegate arm
10-04-2014, 04:13 PM
Mine was a good couple of turns IIRC and there wasn't much thread on the bar, it boosts around 19psi
10-04-2014, 05:10 PM
Ok thanks and what does iirc mean???
10-04-2014, 05:29 PM
Surely. 22 psi is a bit much
10-04-2014, 05:40 PM
It's about the limit of a stock turbo, anything more than that and it'll pop pretty quickly
Anything above 19 is a bit daft imo, if you look at the compressor map for these turbos it clearly shows the efficiency dropping horribly at about 21psi. And that's without thinking about flow limits or exhaust back pressure, there's no need for it.
13-04-2014, 10:04 PM
Mines setup on just an mbc and is perfect, no boost spike or anything
Justin_306DTurbo
306 Ph1 Dturbo Sedan 306 Ph1 Dturbo Estate (VNT) Partner Ph1 (XUD Swap) 306 HDI Stage 3 Estate (RIP) |
| Wastegate actuator | DeeTurbo | 1 | 2,520 |
17-11-2016, 06:55 PM Last Post: Poodle |
| how to adjust the wastegate.... | Arron | 12 | 7,647 |
29-09-2012, 07:50 PM Last Post: Chris_90 |
