Air in cooling system?
I have a split in one of the radiator pipes as its leaking water, would this cause the problem I have when the car is in idle? It fluctuates in rpm and sounds a bit lumpy on start up. After I rev the engine a bit and it runs for a couple of minutes it goes away. Could this be air in the radiator system?
Thanks guys Smile
sounds more like a sensor fault tbh, although yeah the split will be letting air in
replaced the ICV recently?
Project: Formula Peugeot
I would head towards a temp sensor or lambda not warming...
But having a coolant leak is never good...sort it out!
(08-04-2014, 06:39 AM)Piggy Wrote: I would head towards a temp sensor or lambda not warming...
Yeah I'm gonna find out what the pipe looks like and try get a new one then bleed the system and see if that fixes it
(08-04-2014, 06:03 AM)John1.4 Wrote: sounds more like a sensor fault tbh, although yeah the split will be letting air in
What is a ICV?
Idle control valve
(08-04-2014, 10:18 PM)Toms306 Wrote: Idle control valve
Ah okay, I hope it's not the Lambda sensor, they are expensive :/
Shouldnt be more than £30/35 for a decent lambda
(09-04-2014, 06:52 AM)Piggy Wrote: Shouldnt be more than £30/35 for a decent lambda
I had a look on euro car parts and £60 is there cheapest :/ can I get them from anywhere else?
GSF
Ebay
Motorfactors
Etc
(09-04-2014, 07:34 AM)Piggy Wrote: GSF
Ebay
Motorfactors
Etc
Cool I'll have to check them out if it is the lambda sensor that's gone
I had a lambda with a broken heater element on a 1.4, it brought up the engine light but made absolutely no difference apart from that. I would go with the ICV tbh.
(09-04-2014, 08:05 AM)Toms306 Wrote: I had a lambda with a broken heater element on a 1.4, it brought up the engine light but made absolutely no difference apart from that. I would go with the ICV tbh.
I'll try that then Smile can I get them online as well? Or does anyone have one lying about?
I bought a cheap one from ebay, and probably still have it lying about.... Idle was 3k with it.... I bought a branded one after that. lol Should be Magnetti Marrelli iirc, but as long as its branded should be good.
(09-04-2014, 08:30 PM)Toms306 Wrote: I bought a cheap one from ebay, and probably still have it lying about.... Idle was 3k with it.... I bought a branded one after that. lol Should be Magnetti Marrelli iirc, but as long as its branded should be good.
Wow 3k is a bit high?! And I'll look out for a branded one then Smile
Yes, lol. Couldn't drive it with a 3k idle....though it did make stalling impossible haha. lol
(09-04-2014, 09:16 PM)Toms306 Wrote: Yes, lol. Couldn't drive it with a 3k idle....though it did make stalling impossible haha. lol
Haha! I bet, would this be okay?
Looks cheap and unbranded to me? Confused
(09-04-2014, 09:42 PM)Toms306 Wrote: Looks cheap and unbranded to me? Confused
Hmm :/ what brands make them?
Err, Magnetti as above. lol I assume Bosch and/or Valeo as well, they seem to make most things. But just had a quick look on ebay myself and they all seem to be cheap ones, on the first few pages anyway. Confused
(09-04-2014, 09:53 PM)Toms306 Wrote: Err, Magnetti as above. lol I assume Bosch and/or Valeo as well, they seem to make most things. But just had a quick look on ebay myself and they all seem to be cheap ones, on the first few pages anyway. Confused
I'll google a Magnetti one and yeah I've noticed they are the cheap ones :/
Could be gummy injectors?
  cooling system nttrucker 12 8,648 03-08-2013, 08:40 AM
Last Post: nttrucker
