22.2mm master cylinder from hdi/xsi
Like the title please, cheap or free if you could because i plan to reseal it before i use it anyway.
According to the seal kit the master cylinder comes on most 306's. Its stamped on the side anyway.
Cheers.
Edit: Forgot to say must be non abs 4 port. Or have removable blanking plugs if you can remove them?
I have a 4 port master cylinder but dont know if its the size your after ?
On one side will be the part number and on the other in big numbers will be stamped the size. Mine has a load of shit on one side and then 19 in big numbers on the other... So if its a 22mm one it will have 22 on the side.
ok mate ill take a look after work
Cheers bud.
Ive got one 17.50 posted 4 port off a '6
[Image: av5ym8.jpg]
(24-03-2014, 04:37 PM)Jimbo Wrote: Ive got one 17.50 posted 4 port off a '6
To much for me bud i want one cheap! '6 ones are actually worth something because they're an upgrade im just after a boggo shit one that i can put on the 205 after i reseal it.
No worries mate
[Image: av5ym8.jpg]
I will have a look in the parts caravan this week for you mate and let you know
Thanks fantastic mr frost! :p
good luck with the reseal tom, i gave it a go with a ms and was a complete farce and never worked again, tbh if it isn't leaking might not be worth messing with.
(24-03-2014, 09:02 PM)zx_volcane Wrote: good luck with the reseal tom, i gave it a go with a ms and was a complete farce and never worked again, tbh if it isn't leaking might not be worth messing with.
Oh balls, your the only reason i was going to have a go lol! I seen yours in your project thread ages ago so thought id have a crack at it. Hmm.
yeah tried to reseal one that was leaking back into the servo
but it didn't end well, no idea what went wrong either, literally just replaced seals, piece of piss.
ended up locking brakes when up to temp
didn't i write all this up?
Possibly but i cant for the life of me remember where i seen it.
Anyone found one of these??
I should be going up the farm tonight so will have a look
I found a S16 MC last night. I guess its the end bit you measure? That was 19mm so i dunno if it is any good to you
Its stamped/cast into the side what size it is. Research suggests that S16 ones are 22mm. Did you take a picture of it? Or remember if there was a number on the side?
I had alook but couldnt see any markings on mine mate
Hmm thats weird Sad
You got a pik of the location? just in case im being blind lol
The one on my 205 is on the side of the the master cylinder, big numbers on the right hand side.
On the 306s the number is underneath iirc? Sure I used a mirror to look for one last time....though this was about 3 years ago and my memory isn't the best lol.
(27-03-2014, 06:27 PM)Tom Wrote: Its stamped/cast into the side what size it is. Research suggests that S16 ones are 22mm. Did you take a picture of it? Or remember if there was a number on the side?
Will try and look tomorrow
  Wanted: 23mm master cylinder Chris_90 8 5,320 28-05-2017, 04:29 PM
Last Post: Chris_90
  Wanted: 23mm 4 port master cylinder Chris_90 2 2,701 11-01-2017, 08:14 PM
Last Post: Chris_90
  Wanted: Gti6 master cylinder mcglynn 1 1,996 07-10-2014, 07:34 AM
Last Post: Anton
