What size spigot rings do I need?
Wink
I've got some the 307 hdi 17" alloys (challengers) on my estate with 10mm spacers on the rear so the wheels are only on with the extra long bolts and have been told I will need spigot rings as when hit 70mhp cruising along the motorway it vibrates , so does anyone know what size I need?
What size are you spacers etc? Spigot rings are used to change the size of the bore, like when you use after market wheels as the bore size is 73 (iirc) and peugeot is like 65.1 or something I can't remember.
Are the spacers taking away the lip of the hub so the wheel doesn't sit on it? If so it's hi centric spacers you want Wink
Yeah spacers have taken the wheel away from the hub
As Matt said, if there's no lip on the spacers then they're not hubcentric, in which case spigot rings won't help. If there is a lip, which is smaller than the wheel, then you would need them. But that would only be the case if the centre bore of the wheels was wrong, or they're adapters, not just spacers.
Ok cheers, looks like I need new spacers then
Yep Smile you can donate me your old ones whistle
Ill sale them cheap you mean, just need to find these new ones cheap
Haha Tongue get on eBay mate, I found a pair of two, with bolts for £35 before
Got bolts though
  Spacers and spigot rings Welshy_Pete 2 2,531 08-07-2014, 04:38 PM
Last Post: Sambarker
  Alloy wheels, spacers, sprigot rings and bolts mspdan 2 2,518 06-01-2014, 01:56 PM
Last Post: mspdan
  Camber spacer rings ?? Bender 73 43,753 05-09-2013, 11:47 AM
Last Post: Scott
