Front bumper
Hi all.
On my hdi, between the front grill and the top of the bumper there is a slight gap.
I was wondering if there's anything that's causing this or is it time for a new bumper?
Cheers.
Undone the bolts that hold the bumper on and then get someone to hold the bumper up and do the bumper bolts back up
(20-03-2014, 02:00 PM)Frosty Wrote: Undone the bolts that hold the bumper on and then get someone to hold the bumper up and do the bumper bolts back up
Cheers frosty! Smile. Didn't realise it would be something that simple.
You might find that it'll be still sag a little in the middle even after you've done that though - seems to be a common-ish thing.
(20-03-2014, 02:05 PM)powerandtorque Wrote: You might find that it'll be still sag a little in the middle even after you've done that though - seems to be a common-ish thing.
Yeah I've seen a couple before with the middle a little saggy. But I'll do what Frosty said and see how it goes Smile
There are white adjusters at each end of the bumper that can be turned to allow the bumper to sit further forwards/backwards and upwards/downwards.
62k Diablo Phase 1 Gti-6:
Project Thread
Are the three fixing points underneath the bumper intact? because if they are broken that would cause your front bumper to sag a little.Hmm
Cable ties will help solve this.
Haha liking the cable tie one!
Pretty sure all the fixing points underneath are in tact from what I can remember but will have a look over the weekend.
I used 30 cable ties to fix my bumper. The mounts and grille had come away. Yeh its always a bit saggy but forcing it up and doing the bolts up will make a big difference!
  Aero catch front bumper Slam Wagon 5 3,421 04-08-2014, 07:18 PM
Last Post: Slam Wagon
  Front bumper alignment rd070707 19 9,879 08-06-2014, 06:48 PM
Last Post: LewisG
  front bumper removal help ? titch 8 5,178 11-04-2014, 04:13 PM
Last Post: titch
