Front bumper alignment
Im having bother getting my front bumer to sit high enough in the middle to avoid a gap between it and the grille. I have tightened the four nuts best i can at the highest position but it still just sags.
Any ideas how i could sort it?
[attachment=16383]
[Image: 20gh7o0.jpg]
How is it aligned at the wings?
Sometimes you can rotate the eccentric side mounts to fix this. It lowers the rear and brings the front up a tad. Beware though, as you don't want to have a massive panel gap between the bumper and the wings.
Will give it a go bud. Its tight at the wings at the minute so might be some adjustment available
Okay so i tried rotating the eccentric mounts and when i hold the bumper up in the middle to fix it it looks perfect. But when i tighten the 4 nuts it just drops again Sad
Has it had a nudge at the front at any point?
Could be slightly misaligned if its bent the chassis mounting points slightly.
Does your bumper still have the three plastic "tabs" along the bottom of the front?
If it does undo the three bolts slightly then pull the bumper up then get someone to tighten the bolts.
(20-05-2014, 09:05 PM)DeeTurbo Wrote: Does your bumper still have the three plastic "tabs" along the bottom of the front?
Those three tabs will not contribute to the lifting of the bumper though. They are there for front-to-back support.
But if they're pushed forward won't that rotate the bumper around the mounting point that holds it to the car thus pushing the bumper up slightly at the top in the middle?
It has yeah grant but i dont think thats the issue as when holding it up it easily sits flush at the top. Its just a fixing issue
they also help lift the centre of the bumper they stop it rotating(sagging)
Nuts with larger washers?
I only have one of the tabs at the bottom so might make some from some sheet steel see if that helps.
Tbh i think im gonna take the grill and all off again, tighten the nuts as high as possible then use some cable ties in the centre to hold it up
All the tabs on the estate are broken and that sags like a bitch. I'm going to use some ally strip I have at work to sort it for now but I really could do with a new bumper for it.
Yeah im just gonna make some tabs, will be stronger that way anyway
Okay managed to improve this massively tonight by simply taking it all off, bumper lights grill etc and putting it back together. What i realised is that the grille sat perfectly with the lights out but with them in it pulled the grille away from the bumper. So after adjusting the light fixing points this is how it sits now
[attachment=16422]
No perfect under the pass headlight but better. Should be able to sort it with some more tweaking
You need to get someone top hold the bumper up while you tighten the bolts up.
Trust me thats not the problem ive done that. Just need to work out how to get that extra couple of mm below the pass light
I just got a mint moonstone front bumper but the three tabs are broken, is there a way to replace them or?
Plasitc weld them on?
(08-06-2014, 04:13 PM)kentiiboii Wrote: Plasitc weld them on?
I havent got the tabs lol
  Aero catch front bumper Slam Wagon 5 3,528 04-08-2014, 07:18 PM
Last Post: Slam Wagon
  front bumper removal help ? titch 8 5,421 11-04-2014, 04:13 PM
Last Post: titch
  ph3 to ph2 front bumper willJspears 5 4,346 30-03-2014, 10:06 AM
Last Post: willJspears
