Bosch Banjo bolt, m12 x 1.5?
can someone just corfirm the size of the fuel in banjo bolt?
im trying to trace my poor starting and noticed fuel coming out around the spacer/adaptor that the banjo bolt goes into, was going to just change the copper washer but the spacer thing sheered of while undoing it, assume its been over tightened at some point.
anyway i need a new one.
Yer it's m12 x 1.5 you can just fit the banjo bolt straight to the pump that's what I did with air getting in, in exactly same place.
Cheers dude. I was staring at it wondering how that would work.
Till I flicked the feed over and ran it down the front of the pump. All sorted now.
Going to run some fresh clear hose and a different filter so ill sort something more permanent then.
  Bosch pump to bracket bottom bolt blinkyeatu 5 4,032 30-09-2015, 06:48 PM
Last Post: Uberderv
  banjo bolt fitting Ben 2 2,804 12-05-2013, 03:05 PM
Last Post: Chris_90
  Fuel IN banjo puglove 10 8,338 08-03-2013, 11:21 PM
Last Post: Ricky
