Whats this bodge/relay?
So the gti6 all of a sedden wint start. Trying to figure it out. Upon checking fuses and relay I notice this little bodge job.
Any ideas what the relay is ment to to. Any ideas why its bodged like this?
Ive tried following it but ut goes into wiring loom.
Oh wow! I have no idea, but I like the bodge!
Does it have an aftermarket alarm/immobiliser fitted? If so, it's probably related to that
(19-03-2014, 05:05 PM)powerandtorque Wrote: Does it have an aftermarket alarm/immobiliser fitted? If so, it's probably related to that
No just standard.
Not a clue what it is but its a neat bodge!
Its fused, i call that a quality repair!!
Wow. At least its fused. If the fuse isnt blown leave it??
Unplug it and see what doesn't work ...
Looks like the same wiring as the GPS tracker I had installed in mine on my first years insurance. It was hidden behind the top glove box on mine. One wire is permanent live and the other switched so the tracker knows when to turn on and off.
I could be wrong though, just looks familiar.
Isnt that in the heat rear window relay position? I dont have a 306 to hand.
[Image: Atterz.jpg]
why both wires are fused i'll never know . .Big Grin
Read my reply above Tongue Simple explanation! It's eerie familiar.
(14-07-2014, 07:00 PM)Atterz Wrote: Isnt that in the heat rear window relay position? I dont have a 306 to hand.
Nope Smile
They use the same fuse box for all the ph3s and thats where the relay would be for a rear window. Tbh there is nothing bodged about that. Its common practice when taking power for aftermarket kit to use an unused fuse point or relay point like that. In fact, a lot of modern cars have spare points so you can just take a switched feed with a spade connector Smile
That's not a ph3 fusebox. It's the ph2 with the relays in an L shape rather than 2 rows of the ph3.
This thread is pretty old anyway, so its obviously been sorted lol.
(14-07-2014, 07:14 PM)andywhy Wrote: Read my reply above Tongue Simple explanation! It's eerie familiar.
ah ok but is that not the same as a remote wire on a stereo? . . . . .wouldn't think it'd need fusing .. . Smile
  Unknown Bodge Mitch1793 15 7,597 13-07-2014, 04:23 PM
Last Post: WiNgNuTz
  Temp Fix Of A Bodge (Blower Motor) Jenkosowls 12 7,940 19-02-2012, 10:00 PM
Last Post: James
