Removing Engine from DTurbo
Whats the crack then.
Easier to drop out or use a chain/rope and a tractor?
If I was to take it out the top with a tractor I'd have to:
- Remove drive shafts
- Undo lower mount
- Disconnect loom at chassis leg (near gearbox)
- Disconnect heater matrix pipes, clutch cable, tacho sensor
- Disconnect exhaust downpipe
- Undo top mount & gearbox mount
- Lift her out
Anything else I'm missing? Does the slam panel / bumper / radiator have to come out to get enough rotation to lift it out?
Cheersssssss!
Fuel lines... And i find the easiest way is to remove the rad slam panel bumper headlights then lift it off the top mount and swing it out the front then down out the gearbox mount and your clear. And just for reference it took me 3 hours on my own first time i done it...
Gear linkages and pas pipe
  306 DTurbo engine problems VHFK 15 7,088 21-11-2014, 09:38 PM
Last Post: bashbarnard
  How to replace 306 1.9 TD DTurbo XUD9 DHY engine? shazilla 37 23,267 18-11-2014, 09:58 PM
Last Post: daniel.mountain.7
  306 1.9 TD DTurbo XUD9 engine replace questions ECU shazilla 33 26,545 09-09-2014, 08:35 PM
Last Post: shazilla
