Rear brake pads fell out!!! Urgent help needed
Driving along today and heard an almighty bang, went to slow down to pull over & NO BRAKES!! Pads had fallen out, and the piston has popped out. Iv managed just by searching that it's the brake fitting kit is the thing I need. The monkey who owned the car before me probably didn't put any pins in, unless they just randomly fell out.
I'm in Leicester, does anyone know of any motor factors that are open tmoro & are likely to sell the parts I need? (I already have a spare set of pads lying around somewhere )
Cheers
Sorted it today managed to find a parkers open. It's worth a check that you make sure all pins ect are there and are secured properly! I'm just lucky I didn't cause a huge accident
  rear ARB bush size needed. weka 5 6,602 05-04-2020, 01:55 PM
Last Post: Mighty306
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,302 18-04-2019, 10:14 AM
  Uneven brake drag on rear wheels balkan_bozo 2 4,057 21-10-2018, 11:10 AM
Last Post: balkan_bozo
