XUD BLOCK/HEAD DOWEL
I need one of those, sent out first class to mr lobb this evening. Otherwise im going to have to buy 2 from peugeot... Has to be there by tomorrow morning otherwise it'll be pointless. Tall order but i will love you forever if you can sort that for me. Obviously will pay... Someone help quick.
No longer needed had to fork up at peugeot Sad
why did u not just makes some chap
Need one asap tbh. Hence just forking out at pug.
Don't suppose anyone knows the peugeot part number for the dowel do they?
Have got a bag with one in in the workshop, will have a look tomorrow chap
ive got two sitting on the xud 11 block you can have if need be can post out at some point
(12-10-2015, 07:48 PM)Frosty Wrote: Don't suppose anyone knows the peugeot part number for the dowel do they?
6968 35
I found it now on servicebox seems to be part no. 1812 27
(12-10-2015, 08:46 PM)bashbarnard Wrote: ive got two sitting on the xud 11 block you can have if need be can post out at some point
Ok cheers ill see how i get on with peugeot and let you know
6968 35
Different number to what i come up with?
The part number you have it the dowel for the side engine mount the one that has the timing belt tensioner its 14mm in diameter, the part number I gave you is 16mm in diameter.
(13-10-2015, 12:34 PM)ConorTRG Wrote: The part number you have it the dowel for the side engine mount the one that has the timing belt tensioner its 14mm in diameter, the part number I gave you is 16mm in diameter.
Ah it is the 1 on the side engine mount im after. Have to check its 14mm
I messaged you on facebook tom
The dowel is no longer available from peugeot though i have sourced 1 and got 1 coming from an Essex peugeot dealer that had 1 in stock
  Wanted: 1.9 turbo diesel xud cylinder head locating dowel Chris_90 0 1,546 12-06-2017, 03:55 PM
Last Post: Chris_90
  Wanted: Oil Pump Locating Dowel zx_volcane 3 2,109 11-02-2013, 08:51 PM
Last Post: zx_volcane
