28-03-2014, 09:05 PM
I looked into Xl buckets, they army actualy that expensive
Another Diablo GTI6 project (Now on the road!)
02-04-2014, 02:02 PM
So its failed mot again.
Quite gutted about it. But I think station might be trying to do one on me. So taking it back to my usual station.
02-04-2014, 02:20 PM
Have you actually jacked the car up and looked into the faults listed before casting doubt over the integrity of the MOT tester?
1990 Peugeot 205 GTi 1.9 // 1991 Peugeot 205 GTi 1.9 16v // 1992 Peugeot 205 GTi 1.9 // 1999 Peugeot 306 HDi Estate
02-04-2014, 02:53 PM
(02-04-2014, 02:20 PM)powerandtorque Wrote: Have you actually jacked the car up and looked into the faults listed before casting doubt over the integrity of the MOT tester? It all got checked as we was doing the week tbh. Problem is I keep hearing so much bad stuff from people about the mot station ive taken it too.
02-04-2014, 03:06 PM
Fault 002 - twisted brake hose. How do you do lock to lock steering on a REAR brake hose?
02-04-2014, 03:08 PM
(22-03-2014, 07:16 PM)Matt Wrote: You sent it for an mot with no front plate? Dude seriously I read through those fails and thought f*ck me.... Second that. Alot of that stuff was preventable.
1999 2.0 8v Turbo 306
Flying the Flag for the XU10J2TE You Tube: 832 Performance
02-04-2014, 03:10 PM
I've just looked back over the previous failure sheet, and all three of the items that it's just failed on were items that you would have either disturbed or replaced to address failings on the previous MOT.
02-04-2014, 03:15 PM
(This post was last modified: 02-04-2014, 03:34 PM by kentiiboii.)
(02-04-2014, 03:10 PM)powerandtorque Wrote: I've just looked back over the previous failure sheet, and all three of the items that it's just failed on were items that you would have either disturbed or replaced to address failings on the previous MOT. Cheers for information ive added to it. Cant really go over the car now for a couple weeks as im back at work and dont have the time.
02-04-2014, 03:41 PM
(This post was last modified: 02-04-2014, 03:42 PM by powerandtorque.)
Check the actual hub balljoint hole itself if the balljoint itself has been replaced - it's getting increasingly common for these to wear/distort to an oval shape which allows the balljoint pin to move around in the hole even when the pinch bolt is correctly torqued up.
02-04-2014, 03:48 PM
(02-04-2014, 03:41 PM)powerandtorque Wrote: Check the actual hub balljoint hole itself if the balljoint itself has been replaced - it's getting increasingly common for these to wear/distort to an oval shape which allows the balljoint pin to move around in the hole even when the pinch bolt is correctly torqued up. Cheers for the help, will check soon as I can. I have hub on the black gti6 anyway so it's ok.
02-04-2014, 04:44 PM
Did it fail on those originally as they should only retest whatever it failed on....
Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
02-04-2014, 05:07 PM
(02-04-2014, 04:44 PM)Grant Wrote: Did it fail on those originally as they should only retest whatever it failed on.... Legally they should do a full retest, not just check what they failed.
02-04-2014, 05:29 PM
(02-04-2014, 05:07 PM)kentiiboii Wrote:(02-04-2014, 04:44 PM)Grant Wrote: Did it fail on those originally as they should only retest whatever it failed on.... Wrong. Read the bit at the bottom of your pic of the mot failure sheet
02-04-2014, 07:19 PM
As Niall said "Back in 10 days? A partial retest of the failed items and a small charge "
02-04-2014, 07:23 PM
(02-04-2014, 05:29 PM)Niall Wrote:(02-04-2014, 05:07 PM)kentiiboii Wrote:(02-04-2014, 04:44 PM)Grant Wrote: Did it fail on those originally as they should only retest whatever it failed on.... So he should of only done what was failed not a full test.
02-04-2014, 07:25 PM
(This post was last modified: 02-04-2014, 07:25 PM by devils_fuel.)
Bingo unless they have a disclaimer stating that if removed from site and not retested within less that 10 days...this is how you get cheap MOTs, no retest !
I have been always warned about cheap mots and to ask before I book it the smokey old bus that sounds like a tractor...
02-04-2014, 07:26 PM
That's why I said to you this morning pal, at least it'll be quick and when you said he's doing a full retest I found it a bit odd
02-04-2014, 07:44 PM
Well where I usually go they only check what failed. But after mot my uncle told me they have to legally do full retest, byt should of known not to listen to him hea always full of shit.
02-04-2014, 07:48 PM
(This post was last modified: 02-04-2014, 07:49 PM by devils_fuel.)
Kent he may go to where its a cheap mot and no free retest, hence a full retest and full charge again
Love the family mate the smokey old bus that sounds like a tractor...
02-04-2014, 07:55 PM
(02-04-2014, 07:48 PM)devils_fuel Wrote: Kent he may go to where its a cheap mot and no free retest, hence a full retest and full charge again No he goes hle (deggers will know) and they give free retest. like I say half of the time hes full of shit. :-) like I say I doubt ill have time to do the car for a week or so as im back to work tomorrow and covering for a driver for a bit. So when I get chance ill get cam belt done too and take it to usual place. :-)
02-04-2014, 07:56 PM
Oh well best of luck with the rest mate, did some good work this week
02-04-2014, 08:41 PM
(02-04-2014, 07:56 PM)devils_fuel Wrote: Oh well best of luck with the rest mate, did some good work this week Cheers felt a bit fed up today as I was really hoping to tax it and have a little spin before I put it back in garage, just to keep the motivation going.
02-04-2014, 08:49 PM
its a bastard when things like that happen, I have not drove my 306 hardly since it passed the mot, as its got a bloody rust hole the size of a small orange and the back box is due to fall off, something is wrong with the centre pipe, as that's the only part I got replaced, a mate of mine tried to sort the exhaust out last year with better rubbers, but it still eat those, so a replacement system is here, waiting to go on!
Don't get fed up pal, these things happen it's just the joy of owning cars, if your dad's away mate and you want it sorting gimme a shout and I'll get the old rags on
2 issues are only a hub and carrier might be worth getting another leg with those in decent nick, should be no more than 20 - 30quid and possibly a new pinch bolt from pug for a few quid, and the rear brake hose... lock to lock check you tell me pal but im sure we can cross match to mine and see how it should be
02-04-2014, 09:28 PM
(02-04-2014, 09:09 PM)deggerz Wrote: Don't get fed up pal, these things happen it's just the joy of owning cars, if your dad's away mate and you want it sorting gimme a shout and I'll get the old rags on Actually That might be a awesome idea, I might take you up on that. Problem is just need a hand getting hub off the black gti6 as engine has been dropped, So it's pain in arse. Rear brake hose will just be taking caliper of and checking it. Just more of a annoyance than anything. :-)
02-04-2014, 09:30 PM
Shouldn't be too much of a problem pal we will get it off
02-04-2014, 09:38 PM
(02-04-2014, 09:30 PM)deggerz Wrote: Shouldn't be too much of a problem pal we will get it off Wicked well have to sort a day out. May have top but a blow torch if I'm trusted enough :-D heat the hub nut of the breaker maybe easier to get of.
02-04-2014, 09:39 PM
Sound, I can get a breaker bar which is always handy for the tight f*ckers
Project T Phase 2.5 Diablo DTurbo... | Kwik | 90 | 40,706 |
24-02-2021, 11:51 PM Last Post: stevieg |
Diablo GTi6 restoration | Joep83 | 2 | 2,231 |
27-09-2018, 05:28 PM Last Post: Joep83 |
Pic heavy 2yr Build Gti6 road & track | Day666 | 309 | 83,796 |
27-03-2017, 03:14 PM Last Post: Day666 |
