18-02-2014, 07:40 PM
got a very slight oil leak on vacuum end off the head swaped the seal still leaking the odd drip is there a seal on camshaft on that end ? cheers
oil leak at vacuum pump end
18-02-2014, 07:56 PM
Have you got a pic of the pump? if they are the same design as the GTi ones, i always found keeping a new seal on there and running a bead of sealant around the outer edge of the pump where it meets the face of the head works.
18-02-2014, 08:04 PM
18-02-2014, 08:45 PM
That'll be your 'o' ring then.
Tried a new one or some intant gasket? Daily Slag: http://306oc.co.uk/forum/thread-3849.html
Track Slag: http://306oc.co.uk/forum/thread-8873.html
19-02-2014, 08:52 AM
Theres two o rings I had to fit a vacuum pump to the xantia engine when I fitted it, just used 2 new seals and seemed to be fine.
19-02-2014, 11:19 AM
cheers lads will have a look
19-02-2014, 02:27 PM
Pain in the arse ive had a few new seals on it and some gasket sealant and it still leaks.
Ive given up to be honest. |
| Major fuel pump problems, air leak, head gasket? | Dantheman1312 | 2 | 4,308 |
22-08-2016, 09:57 AM Last Post: r3k1355 |
| diesel pump leak | callumh121 | 3 | 2,758 |
08-04-2016, 11:10 AM Last Post: callumh121 |
| Presumed Lucas Pump Leak | ozpug | 4 | 3,657 |
10-09-2015, 12:28 PM Last Post: pioneer DJ paddy |
