Strange starting issue
Well I have a weird problem. First time I turn the key there is no noise from the lift pump and the glow plug light doesn't come on. The car does no start. Second cycle of the ignition you can hear the lift pump and the glow plug light is on - however it will still not always start on this second attempt (though usually does). It can sometimes take 4 ir 5 goes to start but always starts eventually and runs fine.
I've had it plugged in and the only code relates to fuel rail pressure. Any ideas? I feel there are 2 separate faults here.
Thanks in advance.
Do you get any other lights come on with the ignition or is the dash stying dark?
No all other lights coming on as normal
Sounds like a relay issue, i've got a feeling the brown relay controls the glow plugs as well as the lift pump, so i'd suggest starting there.
There is a separate glow plug relay beneath the brown relay.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Right - something I only just spotted. The engine management light doesn't come on the first turn of the key, but only when the car has been left standing.
What have you tried so far?
I have the same problem. Never bothered to check as leaving it 10/20 seconds it starts. May investigate. Seems like a common problem though.
Team disASTOR? Itwasntme
  Strange issue plus more Mrlee 7 4,351 13-12-2016, 06:53 AM
Video Starting issue (PP2000 video) * NOW FIXED DeeTurbo 48 26,744 05-04-2015, 06:37 AM
  HDI starting issue. puglove 16 7,584 01-10-2014, 05:39 AM
