XUD Electrics.
What is the bare minimum amount of wires i can use to start / run-show revs / stop an XUD engine?
I'm doing a trike build. but these engines are new to me. so bare with Tongue
all other needed electrics will be wired up from new. lights, turns, horn..ect ..ect
This maybe moved to XUD section Tongue
...85cc Petrol 0 Doors... - ...135MPG... - ...£17 Tax...
Depends what you want pal. If you want all the instruments to work, water temp rev counter ect
To make it start you need to earth the gearbox, starter wires and a switched live to the pump that's it
Team Doesn't own a 306
I need rev. temps and oil light to pass.. i think.
Is it worth just buying a full loom?
Yes because it would be so cheap you could just cut it down. I know i binned a loom last week Sad
Be easier to have a loom got all the right connections then
Damn it TOM! I'm sure you just started binning all the items I needed for the shits and giggles. Big Grin
Erm buying XUD loom Big Grin
Sure I've got some laying around
If Danny hasnt got a loom, Ted has a couple i think.
(05-02-2014, 01:57 PM)Tom Wrote: If Danny hasnt got a loom, Ted has a couple i think.
Danny.. was there not supposed to be a starter motor on the engine you sold me? lol
Also any luck with the wire loom?
James I might be able to pick a starter up from a scrappy tomorrow, depending on how smoothly tomorrow goes, as i need an oil line for Piritek to make me an oil line up for new turbo.
(05-02-2014, 08:37 PM)Dean Wrote: James I might be able to pick a starter up from a scrappy tomorrow, depending on how smoothly tomorrow goes, as i need an oil line for Piritek to make me an oil line up for new turbo.
Ringing you. Heart
  Damaged electrics, possibly relay?? windrushelectrical 0 2,491 08-07-2019, 10:05 PM
Last Post: windrushelectrical
  last "whats this for" on electrics pug306driver 3 3,474 18-02-2016, 09:30 PM
Last Post: pug306driver
  Test Rig for Tow Bar Electrics insomaniac45 24 16,666 07-12-2015, 07:23 AM
Last Post: THE_Liam
