Threads: 89
Car Model/Spec: 306 d turbo china blue
Right been fiddling with my pump today now I have a nice amount of clutch slip what are the options on moving forward from here who makes decent but cheap clutches for the xud I'm guna td04 or maybe gt turbo it in the near future so something that will hold The power
Threads: 110
20
Depends how much you want to spend. You can go for a brand new decent make like a valeo and that will hold good power and torque or can go for a paddle friction plate which is what I did. Should hold more torque but costs a bit more. I used a cg 4 paddle unsprung friction plate with a new valeo pressure plate. You should be alright with a valeo but if you have the extra £120 ish you can get a paddle friction plate
Threads: 89
How much power does a genuine valeo usually hold? Like what stage of tune I have 9mm lda ground Gov mod k14 running 28 ish psi
Threads: 127
33
Car Model/Spec: ZX Volcane TD
The valeo seem to hold upto about 300 ft/lbs - which even with a td04 and an 11mm pump pushing 180 bhp you might not be reaching.
How long it'll take that kind of abuse for I'm not sure, but likely you'll spit rods before then unless you're upgrading those too :p
If you plan on going for a modern turbo or vnt in the future, paddle clutch will be the way to go.
Threads: 89
Cool I've mailed c g motorsport see what they say
Threads: 89
01-02-2014, 05:50 PM
(This post was last modified: 01-02-2014, 05:54 PM by sherman306.)
There shut now though lol
Your running one aren't you frosty?
Threads: 110
20
Yeah but ring them Monday. Always best to speak to them. Say that your off the 306 forum as they know a few guy off here.
Yeah I am. I prob didn't really need to go for 1 but I fort I may as well upgrade at the time if you know what I mean
