23-01-2014, 12:16 AM
Dont know if i imagined it or not but as a cheaper way of lowering can 106 gti front struts be used on a 306 and if so how much would they lower it by ?
106 gti front suspension
23-01-2014, 07:38 AM
Springs, not struts.
And it may be cheap but not suitable or safe Wishes for more power...
23-01-2014, 10:13 AM
23-01-2014, 10:48 AM
Lowering springs on gti shocks come up on here for £30-50 for a pair...so its not worth trying to save a tenner
23-01-2014, 12:38 PM
Just do it properly mate. No point messing around with parts which arent meant for the car.
23-01-2014, 12:57 PM
why this is hear could i put the springs off my 106 (eibach -30mm) on to the 205?
23-01-2014, 01:18 PM
Using 106 springs on 205's is common enough, although it's usually only on the lighter TU models.
With a diesel engine 205 you're going to need different springs though - even standard 205 GTi springs lower diesels a fair amount (indeed, it works quite well coupled with a GTi spec beam and is how I ran my old 205 STDT). I would imagine that 106 or 205 springs on a 306 would be far too low and the spring rates badly mis-matched. 106's and 205's are broadly similar weight wise, whereas a 306 is much heavier.
Front top spring suspension | Welshy_Pete | 4 | 1,825 |
21-04-2018, 09:52 PM Last Post: Mighty306 |
front suspension | johnnygomez | 5 | 1,716 |
10-12-2016, 12:36 PM Last Post: johnnygomez |
fitting a front suspension ball joint | impotentials | 3 | 2,030 |
29-10-2016, 05:46 PM Last Post: Poodle |
