Battery in boot and fan wiring
Hey all i am planning on putting my battery in the boot but am abit stuck on what size cable i would need and best way to route it.
I have got 2 slimline fans aswell i want to run them too a switch as i have lost my loom for fans can someone help with what i will need to run then too a switch.
Can someone help me please
Thank you
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
Ok with the battery, you will need something fairly chunky. I would recommend going to a scrappy and ripping the battery wiring out of a old BMW 3 series as these have the battery in the boot. This is ideal. Need to make sure that battery is secured and all wire joints are secure. Loose connections could cause odd problems and damage later down the line.
With the fans, what wiring have you got? Just the wiring up to the plug in the fan cowling? It depends If you just want them on a switch or want them automatically controlled.
  Moving battery to boot. Matt 9 5,998 28-06-2016, 12:44 PM
Last Post: Matt
  Boot light draining battery Dreijers 8 5,393 26-02-2015, 10:12 AM
Last Post: Dreijers
  Flat battery/ can't open at to charge battery Aaron _d95 18 15,871 01-12-2013, 08:26 PM
Last Post: C2K
