12-01-2014, 11:45 PM
Rebuilding a xud9 engine. What piston rings do you recommend?
Thank you!
Thank you!
Engine Rebuild question
Thank you!
13-01-2014, 11:45 AM
Has anyone tried any other piston rings than oem ones? Not in my budget the oem ones. Also i see the compretion ratio for the xud9 is 21.8. What is that in bar/psi?
13-01-2014, 11:50 AM
don't cost cut when bulding an engine it will only bite you in the arse in the long run
13-01-2014, 01:34 PM
JP
13-01-2014, 01:40 PM
A ratio is ratio, doesn't have a unit
13-01-2014, 01:55 PM
Ok. 26 bar on 2 pistons and 27 bar on the other two. Is is ok or change the piston rings?
13-01-2014, 02:05 PM
compression @ 26bar sounds good to me
13-01-2014, 02:27 PM
Again like Jammapic it's not XUD's specific experience, but I've always found a good quality aftermarket piston ring set is fine. On the petrol XU rebuilds I've carried out I've used Federal-Mogul rings which are readily available and typically much cheaper than OE.
1990 Peugeot 205 GTi 1.9 // 1991 Peugeot 205 GTi 1.9 16v // 1992 Peugeot 205 GTi 1.9 // 1999 Peugeot 306 HDi Estate
405 overhaul and engine rebuild | 405D-turbo | 4 | 3,984 |
16-11-2015, 11:41 PM Last Post: daveylennon93 |
| engine rebuild questions | blinkyeatu | 1 | 2,588 |
03-03-2015, 01:21 AM Last Post: Dave |
| Help Needed On Engine Rebuild (Companies) | Lwilliams | 12 | 6,780 |
16-12-2013, 06:58 PM Last Post: Lwilliams |
