GTI-6 Gearbox- Advice needed
#31
Ok issue resolved, now have the cable and lifter, next problem, can anybody shed any light on how the cable is fitted???. and does it run underneath the car???
Cant seem to see where it goes?
If its a case of it goes through the bulkhead, is there a grommet anywhere as i dont really want to start drilling holes to fit it Confused
1999 2.0 8v Turbo 306
You Tube: 832 Performance
What the reverse cable? It goes out of the top of the box and and back through the bulkhead behind the centre console iirc.
Cheers. I think because mine is not originaly a GTI-6 there is no grommett there for it to pass through. Do you have a pic of where it goes into the bulkhead?. I was thinking of drilling a small hole at the back of the gear selector then running the cable between the heat shield and the body.
I don't but will tomorrow when my engines out Smile
(31-01-2014, 09:32 AM)Niall Wrote: I don't but will tomorrow when my engines out Smile
Cool, many thanks
Some do some don't as the shells are all basically the same
I fitted this cable in my ph1 DT for the 6 box, if you look there is a little flat on the bulkhead at an angle, this is where it goes through, I just drilled a hole, and the cable has a grommit on it, oem+!
Cheers for posting this guys. I am going to have to do this soon too.
[attachment=13286]
There you go mate. It's the grey cable.
Many thanks mate
Just out of interest is that the AC drain pipe next to it?
Yeah Sad
  306 1.8 16v XS- Advice needed PUGNUT_XS 46 14,320 28-08-2013, 01:29 PM
Last Post: PUGNUT_XS
