just picked up a hdi cold start problems
hi guys
randomly picked up a 02 hdi estate 2day
seller told me when its cold it won't start unless you use cold start Nospeak or head the manifold up with a hair dryer etc i thought glow plugs but see on here they don't really need them and seller said he has done them checked voltage to them etc (no glow plug light on dash tho??
don't a bit of looking about and see the lift pumps can be a problem but i can hear that working parking the car up on the drive tonight and see what happens tomorrow.
thought i would post up and see if any one else had any idea's same problem so i can maybe speed up solving it
I think the glow plug light only illuminates under a certain temperture.
[Image: av5ym8.jpg]
(04-01-2014, 05:36 PM)Jimbo Wrote: I think the glow plug light only illuminates under a certain temperture.
hurmm would that mean there is a sensor to tell them to work and that could be wrong?
Possibly, get a fault code reader on it and get some codes
[Image: av5ym8.jpg]
check the glow plugs they are used even if the light dont come on Wink
thnaks guys
right went out this morning and it just turned over starter moter started giving up i only turned it over for 10~15 secs a go so noting gets to hot or f*cked in the end (as it started raining) i just did what i didn't want to do and sprayed some cold start down the intake and boof its alive going to get it on my mates scanner later and then test the glow plugs noticed earth was louse on the battery so tighten that up and life lead is shite to so i'll change that at some point.. these engines need good starter motors to wind them over quickly? also fixed the air horn why i was under the bonnet and wet so least if i don't fix the problem i can beep out me swearing :Hello
car starts fine for the rest of the day once messed about with it in the morning
got the ecu plugged up
got
P1521 - clutch switch?
po100 air mass
p1112 - fule press (lift pump? new filter?)
p0380 - glow plug relay (will a xud one work?)
po335 - rpm sensor
so next weekend trip to scrap yard is booked going to look up whats were before hand and do a small bit of shopping i know should buy new but its just a smoker/tip run / not care but make reliable car
Is the car reading any RPM when its cranking? that could be the issue and it starts warm as the tollerence of the sensor changes when warm (metal expands, gets closer) maybe?
To fix the issue (if you have revs cranking) id replace the glow plug relay and lift pump first.
I'll put money on Crank position sensor there or lift pump failure.
If it turns out to be high pressure pump, I have one for sale very cheap
[Image: av5ym8.jpg]
(05-01-2014, 06:02 PM)Ruan Wrote: I'll put money on Crank position sensor there or lift pump failure.
CPS is what i am going to change 1st mate as rev gauge is out and i see when looking stuff up on the net some one had the same problems and that fixed it after he done loooooads of other bits
thanks for the replys and thoughts guys will keep it posted any other idea's welcome to Smile jimbob do you have any of the other bits cheap
am i right inthinking the CPS will be round were the gear box bolts to the engine?
The CPS is round the back of the block on a bit of webbing that juts backwards away from the block (at the gearbox end) with the sensor bolted through it to 'look' at the flywheel.
And yeah if the rev counter is out as well as saying rpm sensor issues thats the first thing id look at as I'm pretty sure the car needs to see rpm or even a certain rpm to start.
Sits above the diff under a little metal heat-shield.
crank shaft sensor sits directly below the thermostat housing....held in with a 10mm bolt
(06-01-2014, 07:53 AM)gareth7 Wrote: crank shaft sensor sits directly below the thermostat housing....held in with a 10mm bolt
God your right
What the hell engine was I thinking of?????
God knows mate lol....
Mine decided to break down just before Christmas.....lift pump and CS sensor failure at the same time! Fortunately I had a spare CS sensor so that was a free fix. Awkward to get at, took longer removing the air box and moving the loom out of the way than it did to change.
When the old one came out it was pretty obvious it had issues Wink
[Image: 2013-12-05095249_zps38f00636.jpg]
God your right
lmao
(08-01-2014, 06:33 AM)gareth7 Wrote: God knows mate lol....
Yes, that is definitely broken! lol
thanks guys i'm on it this weekend with trip to scrap yard
when the ecu was plugged up it also said the glow plugs didn't work so last night I just wired them to a bit of wire for the moment that I put on the + of the battery for 20sec that and a tiny spray of cold start it started up loads easyer then before ThumbsUp
I have always got the glow plug fault when iv scanned a hdi with starting problems. Usually by the time ive fixed it i find that its never anything to do with the glow plugs so i wouldnt worry too much about that code
thanks L.J
right guys bit of a update swapped out the cps and changed the cam one to as i picked up a few still the same fault but again bit of cold start and she fires up and is fine for the rst of the day rev gauge is still out but works any other thoughts lift pumps kicking in and then back out little pissed off as wasted 1/2 a lush sunny day and still no joy any one fance a battered estate for £300 is the way its going and i'll go buy anther xud lol
If the lift pumps kicking in and put id be inclined to say either a dault with the relay or an earth, or else the pump/motor itself.
thing is once its run once its fine rest of the day till left for 8hours/over night. doesn't run sluggish or underfule so could it still be pump related I have a new set of bosh glow plugs coming and will change/check the glow plug realy
I had this shortly before my ecu died... :S
  Cold start 2.0hdi tommyboii 10 5,411 11-03-2016, 01:21 PM
  2.0hdi hard to start from cold stu9 19 13,310 24-02-2013, 02:13 PM
Last Post: DeeTurbo
  Lumpy idle when cold also longer to start when warm Chris_90 21 13,925 14-08-2012, 10:28 AM
Last Post: Chris_90
