30-12-2013, 10:57 PM
Anyone know how big of a job it is to do a clutch on a d turbo?
d turbo clutch
30-12-2013, 10:59 PM
3hrs with decent kit and a helping hand...4/5hrs if on own and not done it before
30-12-2013, 11:05 PM
Is there a tutorial on here? Never done a clutch before but am pretty good with the spanners.r
30-12-2013, 11:09 PM
If Chris can do one anyone can (i am so sorry)
But in all seriousness expect it to take a weekend if you haven't done one before then if you catch on quick it shouldnt take that long. If you can having someone who has change a clutch before would be of great advantage. If you can find someone whos done an XUD clutch before, even better.
30-12-2013, 11:14 PM
Yeah if your on your own, the biggest problem for you will be lying on your back trying to get the box back on. Its a complete bastard of a job to do. Much easier if someone can lift it from above then you can lie underneath and guide it in place. They will not go in if they don't go on dead straight!
30-12-2013, 11:16 PM
raise front of vehicle and support
drain gearbox remove from wheels remove driveshafts - note two 11mm nuts holding two retain bolts on engine lower mount which hold one shaft in remove all the crap around the gearbox, wiring, clutch cable, starter etc undo the clutch release arm bolt and remove clutch release arm support engine undo gearbox mount and remove mount supports support gearbox - handy friend witha jack undo all gearbox bolts between bell housing and engine block remove gearbox remove clutch clean flywheel surface fit new clutch - use alignment tool to centralise refit gearbox ensuring clutch arm slots onto clutch release bearing now put it all back together, fill up with fresh oil and have a cuppa T (worthwhile attaching the clutch arm and cable early on to check it all has aligned ok) Wishes for more power...
30-12-2013, 11:22 PM
Also worth noting you don't have to undo the hub nuts if you can't / don't want, can just split bottom ball joints and pull them out the way
30-12-2013, 11:31 PM
Sorry to hijack your thread, but does anyone have any suggestions as to what one could use as an alignment tool if one doesn't have one?
Something that made my life loads easier last time I did one if you have a strut brace (or a big wooden post laid across the strut towers), loop a ratchet strap around it and use it to support the weight of the box when you're refitting it, loads easier to guide it on when you don't have to hold its weight as well. That and removing the half-shaft under the sump, absolute lady garden of a job.
(30-12-2013, 11:09 PM)Tom Wrote: If Chris can do one anyone can (i am so sorry) Its tricky removing the pin for the clutch arm have a spare arm ready just incase you have to bend it, tbh other than that it's all pretty simple. First time I did took gearbox off and found it very easy (apart from 3 hours shouting at the clutch arm) and took about 10mins to get the gearbox back on, on my own all though it is fairly heavy. Only one way to learn tho just jump in and do it, that's what I do didn't no anything about the 306 tbh before joining here, now can do almost anything. Just in the middle or rebuilding an xud engine now so come a long way. (30-12-2013, 11:31 PM)WiNgNuTz Wrote: Sorry to hijack your thread, but does anyone have any suggestions as to what one could use as an alignment tool if one doesn't have one? Valeo clutches come with a plastic alignment tool well the used to, but if not just just a long reach socket with some tape round it.
30-12-2013, 11:37 PM
30-12-2013, 11:38 PM
Yeah, not when it's second hand and part used. Only cost me postage really though, thanks to Tom on here.
30-12-2013, 11:41 PM
Danglyballs, just go to a local garage and ask for one. Most clutches come with a plastic one so garages will have loads hanging about
30-12-2013, 11:44 PM
Hmm...good shout sir. Might just do that! I shall stop taking over the OP's thread now though. Thanks for the tips guys!
31-12-2013, 12:26 AM
Selling as spares or repair as I dont have time
31-12-2013, 08:45 AM
Wingnutz...you can just do it by eye if you cant find one
31-12-2013, 09:56 AM
Fair enough, i know a couple of garages round here, so i'll try them first, might go see the guy with the sweet looking Astor 6, and if its there i'll get some pics of it.
31-12-2013, 11:00 AM
I left the o/s drive shaft in the whole way through, doable but was a bit of a twat to realign at the end!!
306 D turbo Clutch options | AssMonkey13 | 30 | 7,317 |
23-11-2013, 04:56 PM Last Post: AssMonkey13 |
