Spraying a bumper
Spraying a bumper
I want to get this bumper i have sprayed on the cheap lol i also want a good finish Big Grin
Now i have plastic primer in a rattle can and i also have hi build primer in a rattle can already.. Do you think i could get a decent finish if i primed out of the cans and then just buy a half liter of water based colour and spray it out of a spray gun.. Same with lacquer.
I'm just thinking the primer will be flattened down anyway so it doesn't matter how its applied? Thanks for any help Smile
Aslong as your prepare the surface correctly before doing anything the rest will usually turn out good, unless your an idiot with a rattle can Smile
Just keep the layers even and when you spray the colour on make sure you spray it all in the same direction so you dont get uneven distribution Smile
306 HDI, soon to be XUD
declantg Wrote:Just keep the layers even and when you spray the colour on make sure you spray it all in the same direction so you dont get uneven distribution Smile
This is a must if it's a metallic paint otherwise it will look like a 2 year old has done it!
^^ Ideally I would do even coats in alternating directions if it was me Smile
But as said, as long as the prep is good then you should get a decent finish.
Team Orange Engine Bay
mark_airey Wrote:^^ Ideally I would do even coats in alternating directions if it was me Smile
Only if it is non metallic Smile
If you say so Wink
I feel like you no something that i do not? lol
You want the fleck in the paint all to lye the same way or else it will look shit. So spray from left to right. Don't go left right then reverse then left right again. If you get me.
Im handy enough with rattle cans lol i have my own spray gun too which i can use but its just i have the primer here so i might as well use it..
Do i spray ordinary primer over plastic primer? Or straight to colour after it?
Normal primer over plastic primer Smile
If the bumpers already painted you don't even need plastic primer. As for spray direction, the base layers of colour don't matter, you should be flattening them anyway. You only need a final coat of colour to be in the same direction for the metallics to lie properly, just build up your initial colour as normal.
Once it's primed though you're usually good for most paints on top.
Oh and remember when doing each coat to do the cutting in and details first before the large flat areas.
Thanks very much cwspellowe Smile great help!
cwspellowe Wrote:If the bumpers already painted you don't even need plastic primer. As for spray direction, the base layers of colour don't matter, you should be flattening them anyway. You only need a final coat of colour to be in the same direction for the metallics to lie properly, just build up your initial colour as normal.
Thank you!!!! Clearly your wrong like me though lol
Oh, as above, but if its a ph1 or 2 bumper and you plan to paint the black section then you will need to give that a blast with the plastic primer first Smile
if its staying black then just mask it off (obviously)
Phase 3 bumper thanks mark Smile also have the side strips and back bumper to colour code so ill keep that in mind!
  Spraying/Painting Alan_M 0 891 26-11-2013, 10:00 AM
Last Post: Alan_M
  centre console spraying NottsPug 6 2,463 24-07-2013, 06:58 AM
Last Post: kentiiboii
  Spraying an intercooler Icywalts 5 1,752 07-07-2013, 05:59 PM
Last Post: Sambarker
