Meridian Blower Motor Resistor
Hi all, was wondering if someone could help me locate the resistor for the heater blower motor on my 1999 306 Meridian 1.9TD, its not under the scuttle panel like some 306s and I can't see it after taking the blower motor out from under the dash on the passenger side.
Anyone got any ideas?
Cheers, Phil
Yours might be in the centre console near the dash!
Cheers man, will have a mooch tomorrow!
1999 meridian will have air con (well not working obviously!) in which case it doesn't have a resistor.
(29-12-2013, 11:19 PM)Niall Wrote: 1999 meridian will have air con (well not working obviously!) in which case it doesn't have a resistor.
Ah right, Thank you sir! Saved me a lot of frustration there Smile
Any idea what might be causing the blower motor fuse to be blowing? The blower worked momentarily when I changed the blown fuse but then blew my new fuse after a couple of secs, thought it might have been a problem with the resistor, but it doesn't have one so I can rule that out!
A short on the blower motor wiring - check the large plug on the motor and the wires from it.
Cheers mate, that could possibly be the case, I tried another fuse today after disconnecting the A/C incase it was anything to do with it, the blower came on as it usually does but stayed on for longer, started smoking and then the fuse went, so after some investigating I found that one of the pins in the plug for the heater control panel hsd burnt out. What i believe to be a diode has split, you can see where the smoke/heat has stained the plastic casing! I'll try and get some pics up tomorrow once i have figured out how to.....
  306 Blower motor replaced and working but no air coming from vents? Zubes3 4 4,668 19-09-2020, 04:58 PM
Last Post: Zubes3
  RESISTOR BLOCK help plz Di3Ny 4 3,394 12-05-2016, 06:29 PM
Last Post: Pingaz
  Update: blower motor issue full fan speed all the time rich_n_stace2014 5 4,109 01-05-2016, 08:24 PM
Last Post: rich_n_stace2014
