Front headlamps problem
Rainbow
My front headlamp on the driver side wasn't working properly so I cleaned the connections up and it worked ok after that.
But then today the full beam sticks on the passenger side and the driver side only goes on side light.
So not sure if its a fuse or some thing.
Sounds like you've got a short or a dodgy earth somewhere. When i have headlight issues i give the light a good kick that seems to solve it.
(28-12-2013, 12:20 AM)Tom Wrote: Sounds like you've got a short or a dodgy earth somewhere. When i have headlight issues i give the light a good kick that seems to solve it.
I will have a look at the wiring to see what's going on.
Has to be an earth, always is with random issues. There are several on the pass inner wing but iirc the headlights get their own behind the units.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(29-12-2013, 09:10 AM)C2K Wrote: Has to be an earth, always is with random issues. There are several on the pass inner wing but iirc the headlights get their own behind the units.
It must be a earth or wiring around the headlamps.
I had a look at the 3 connections on the h4 bulb. The connector on the brown wire the metal part was dirty. So I cleaned the hole connector up and the other side to.
The full beam goes on and of now like normal. But need to change the bulb as it must of blown the bulb I will swap the bulb around to see.
(30-12-2013, 12:49 PM)Welshy_Pete Wrote: I had a look at the 3 connections on the h4 bulb. The connector on the brown wire the metal part was dirty. So I cleaned the hole connector up and the other side to.
I changed the bulb now everything works fine thankfully. So the dirty contact made all those problems it just shows.
Question HELP PLEASE, front wiper problem losing my mind Mattcheese31 53 37,885 01-01-2014, 01:02 PM
Last Post: Mattcheese31
Rainbow Relay morette headlamps Welshy_Pete 2 2,600 22-07-2013, 09:39 AM
Last Post: zx_volcane
