02-01-2014, 09:30 PM
Another one from this corner of the earth. We really need to sort a Bicester meet when I'm back from holiday.
mercades c250 gt20
03-01-2014, 06:57 AM
ah lots of local people, a meet would be good
ive got a scooby Td04 on at the moment, but i think i got lucky when i guessimated the angle, and welded the exhaust. ill have a look at rickys thread.
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning) 205 STDT -new project
03-01-2014, 11:33 AM
Something like this www.ebay.co.uk/itm/321233914589
03-01-2014, 12:02 PM
Good link there...handy that...
some turbos have the V band flange on them already so das is goot Wishes for more power...
03-01-2014, 12:12 PM
So can you weld that v band thing to the turbo? Looks good idea saves the messing of trying to get it at the right angles
i think the v band on the gt20 is slightly bigger than 3 inch (not a common size), from mercades the correct clamp for that turbo is around £15 quid, so i could buy that and then make a custom band to weld to my three inch elbow.
306 XUD9 gt2052s
03-01-2014, 12:44 PM
I used a 3" elbow with v band clamp, had to grind down the mating surface on the turbo for the clamp to fit though. I also used a TD04 actuator aswell. I had mine on a dyno but made poor results because it was very de tuned because I didn't want to blow it up, I've seen how quickly the EGT's rise on boost.
heres i few pictures
sorry for hi-jacking your thread by the way yeah i thought i might have to square off the turbo face. so you used a 3 inch v band clamp?
306 XUD9 gt2052s
03-01-2014, 01:02 PM
That's identical to how mine was.
18-02-2014, 10:38 AM
Ive just acquired one of these Merc C250td turbos and it is confusing the hell out of me lol
The id plate says the following; GT20 A6050960599 454 156 - 1 AL0001 A/R Turbine side is .38 A/R Compressor side is .51 You would think it has to be a GT20 of some variation but the dieselavante site gives it as a GT25c based on the A6050960599 nr so it is contradicting itself. If it is a GT20 has anyone a clue as to what derivative of GT20 it is?
18-02-2014, 12:49 PM
It was said some were that gt25c is bascily a gt20 just the old code for it.
20-02-2014, 09:23 PM
Few measurements taken from the turbo i have;
Comp Exducer - 52mm Comp Inducer - 40mm Turbine Exducer - 52mm Turbine Exducer - 40mm Rough measurements, only had a tape measure, my uncle nicked my calipers. Does that sound like a GT2052s, or at least a version of one?
20-02-2014, 10:01 PM
I have this turbo on my C250TD
GT20 A6050960599 454 156 - 1 AL0001 I'm trying to find a rebuild kit for it as the bearings have way too much play in them. Anyone know where I can get a kit from ? I did order one from ebay but the seller supplied a GT15-25 universal kit (which just doesn't fit) and now can't supply the right kit. I even sent him the full part number before ordering.
21-02-2014, 10:36 AM
Contact Garrett and see if they provide a service kit for it?
22-02-2014, 09:56 AM
I've bought a kit of these before-
Melett Limited Unit N Zenith Park Whaley Road Barnsley S75 1HT United Kingdom Main Sales Line +44 (0)1226 320939 Wasnt your turbo but i am sure they could sort one out |
gt20 exhaust system | Chris_90 | 13 | 2,976 |
15-10-2014, 07:42 AM Last Post: Mike |
Gt20 | sherman306 | 32 | 7,542 |
14-03-2014, 05:23 PM Last Post: Chris_90 |
TD04 to GT20 oil feed | anto | 11 | 3,384 |
07-03-2014, 11:46 AM Last Post: anto |
