Vinyl dye RED gti
I'm looking for some red vinyl spray paint, to freshin up my 205 gti carpet
Any ideas what would be a good match
Does vinyl spray leave a crispy finish as regular 1k aerosol would leave?
vinyl spray will leave a 'crispy' finish yeah, not as much, but if you're not careful then it'll mash together and look worse than when you started
ideally you'd use this kinda thing.. i'm assuming you've got the BRIGHT red gti carpet?
http://store.detailking.com/Red-Carpet-Dye_p_1915.html
not that expensive and easy to use - mix it up, put it in a spray bottle, apply it, wipe it in a bit, leave to dry - enjoy carpet Smile
Project: Formula Peugeot
I was looking at carpet dye first but I couldn't find a uk supplier don't really want to order from the us
Have you any links to any good websites
just found some.. fabric spray in red
i think autoglym do some, but the main ones you can find in liquid rather than aerosol form are black, best idea would be to ring around some valeting companies and see if they would be able to do a re-dye (it also depends on the wool content of the carpet... if it's mostly nylon then it's new carpet time)
  Vinyl Wrap Removal Toms306 1 2,058 01-07-2014, 10:53 AM
Last Post: kentiiboii
  Door Vinyl bigtone0777 17 8,513 14-08-2013, 09:16 PM
Last Post: Kezzieboy
  Painted Door Vinyl Eeyore 8 5,647 24-03-2013, 10:29 AM
Last Post: 306GT30
